This is a sticky topic.
  • Mystikal
    Wheel Fitment Expert
    • 9602
    #4636
    Originally posted by drivnvordaedge
    This is for my e30. .. I'm running e30m3 suspension with after market springs. ....
    I want to run a set of BBS RK 15X7 ET 35 ....
    I was running m systems with 215/40r17 ... and they rubbed in the back
    Why run E36 offset RX's with E30 M3 suspension? They'll work with 15mm spacers, but the proper offset versions look much better (concavity).
    • Mystikal
      • 9602
      #4637
      Originally posted by ethrtyiS
      195/45/16 or 205/45/16
      16x8.5 et13
      205/45 imo.
      • Mystikal
        • 9602
        #4638
        Originally posted by mikejungle
        Hey guys, I've got BBS RA's: 6j x 15 x H2 (what does H2 mean?)
        it also says "253 ET30" on it...don't know what that means either.
        What's the widest I can run on em, what sidewall height do you guys recommend and should I put thinner tires up front? I think I have 205/50/15 on the back and 195/50/15 on them right now.
        Oh, also, what brand and type of tire do you guys suggest? Should I search around for a used set or should I get brand new?
        That's a lot of questions, but I didn't want to get flamed for starting a new thread.
        Thanks
        They're 15x6 +30. 195s are the widest you're going to want to run on a 6" wheel...205/55 is possible but not optimal. 195/60 or 195/55 are closer to the proper diameter.
        • Mystikal
          • 9602
          #4639
          Originally posted by tfritz
          What size tire for a 16x7.5 with either a 0et or 5et (offset of rim is either 20 or 25, I dont recall, and I will be running 4x100 to 5x120 adapters). Car is sitting on H&R race springs with 15mm drop hats.
          Thanks.
          195/45 or 195/50. Rolled rear arches.
          • Mystikal
            • 9602
            #4640
            Originally posted by Rowanese
            15x7.5 et30 with 205/50 r15, sound good?
            Paper thin strut clearance. Will work with most tires, but not all.
            • silver4dr
              • 16
              #4641
              Mystikal, I'm new to the site. Just picked up a 90 4dr and it has some rota 15x8 e4 wheels currently with some falken all season 195 50 15s. Car is lowered on GCs and fenders are rolled. How much tire can I fit do you think? BTW I am deciding between XSs, Azenis, RS3s, and Star Specs.
              Thanks!
              • Mystikal
                • 9602
                #4642
                Thanks!
                So they're +4 offset? Your tire size is about maxed out then, but if you're willing/able to roll more then 205/50 is in the cards. I've used all four of those tires and have a soft spot for the R-S3 right now. Star Specs are unbeatable for wet/dry combo though.
                • giantkeeper
                  • Aug 2009
                  • 1416
                  #4643
                  I came from Azenis and am running the RS3 right now. I absolutely LOVE these tires!
                  Always Always go for the reach around if there is an option
                  • silver4dr
                    • 16
                    #4644
                    cool, thanks guys.
                    • mikejungle
                      • Apr 2007
                      • 361
                      #4645
                      Can you tell me why it's not optimal?
                      Will there be a noticeable decrease in performance when I make the drop from 205's to 195's? Or will it feel better because it's "optimal"?
                      Thanks.
                      1985 325e
                      mods:
                      Powerflex CABs
                      MOMO Corse Exhaust
                      euro bumpers with BBS front spoiler
                      e36 m3 shifter
                      uuc clutch stop
                      • willworkfore30s
                        • Aug 2011
                        • 1090
                        #4646
                        My B
                        • 325ix
                          • Aug 2009
                          • 7783
                          #4647
                          ^wrong section bud.
                          • jaywood
                            • Jul 2010
                            • 4528
                            #4648
                            Front: 16x7.5 et35
                            Rear: 16x9 et15
                            Brock b1
                            BC coilovers
                            Probably a 205/45 tire.
                            • Rowanese
                              • Oct 2009
                              • 36
                              #4649
                              will it be safe to try as it is or should i get spacers? if so, what size for the front? rear?
                              thanks
                              • drivnvordaedge
                                • Apr 2008
                                • 369
                                #4650
                                I have them laying around my garage and I would like to get my car off jackstands as I sold my m systems. ..
                                So ill be needing 15mm spacers to clear the strut? ... test fitting it seemed like it cleared but very close to the strut for the tire
                                .... what would be an optimal tire size?
