This is a sticky topic.
  • ZenkiOwns
    • Jul 2009
    • 496
    #5431
    Just bought Borbet type S in 16x9 et15 square set up.
    I'm guessing 20mm spacers and I'll need to order a stud conversion kit. Is this correct and do you guys have recommendations for brands for both?
    Thanks.
    • GunMetalGrey
      • Dec 2010
      • 1499
      #5432
      My 16x8 +20 setup hits the strut tower in the front! Just so your aware.
      What is the smallest spacer you know of? I may just make some lol.
      EDIT: e30rob makes all kinds of spacers, 3-8mm are available. Perfect!
      • ZenkiOwns
        • Jul 2009
        • 496
        #5433
        That's what I'm worried about! What do you guys think would be an appropriate spacer size?
        As for the lug stud conversion, I would prefer them to not poke out past the face of the wheel either.
        • rso
          • 19
          #5434
          how would 16"x9mm +20 go just got offered them for a cheap price would the work with a e30 ? elp
          • GunMetalGrey
            • Dec 2010
            • 1499
            #5435
            I just put 16x8 +20 on mine, and to do a 16x9 you would need at least a 1 inch spacer
            • GunMetalGrey
              • Dec 2010
              • 1499
              #5436
              I think lol.
              • rso
                • 19
                #5437
                on the front i am guessing ? so it would fit
                • Mystikal
                  Wheel Fitment Expert
                  • 9602
                  #5438
                  Originally posted by F34R
                  I was checking about tire combos here:
                  my current setup that will be leaving is Rota Slips with 225/50/16(632mm of height) Really tall combo IMO not my doing PO did it.
                  But I looked up some images and saw 215/40 and 45s for 17" that I will be running.
                  With the 17x8 in the front I know I wanna stick with a 215 for clearance on my adjuster nut for the coils. But with the rears 17x9 and 235/40/17(620mm) Then switching to the fronts 215/40/17(604mm) that is not close to the rear and looks really tiny in pictures on google. the 45 ratio looks alot better and has a final of 626mm. 6mm is not anything to notice. Again fenders don't mean a thing to me. Only question is do you think I should match ratios to have an over all matching height?
                  And vs the Rota's I will gain more clearance and the custom spacers will take care of the adjuster nut issue since the wheels are a 38et.
                  Never combo'd different sidewall ratios so that is why I am asking. Seems logical to me though. Thanks again man
                  205/45. Problem solved.
                  • Mystikal
                    • 9602
                    #5439
                    Originally posted by e30loverSC
                    Scenario 1: h and r sports and 17x7 beyern mesh wheels. What tire size would look good and be ideal?
                    scenario 2: JOM coilovers and 17x7 beyern mesh wheels. What tire size for this setup?
                    Offsets.
                    • Mystikal
                      • 9602
                      #5440
                      Originally posted by kamotors
                      Looking for a good auto-x track setup
                      currently have H&R race 15mm spring pads rear, drop hats in the front. Rear fenders already rolled.
                      I want some Apex arc 17x8 et20 with either a 235/40-17 all around or 245/40-17(cheaper).
                      Just need to know if they would clear the struts and and be able to clear rolled fenders.
                      +25 you mean. 235/40 is the ideal size, 245/40 will likely contact a few areas.
                      • Mystikal
                        • 9602
                        #5441
                        Thanks.
                        3mm front spacers, and re-use the stock bolts. Done.
                        • Mystikal
                          • 9602
                          #5442
                          It shouldn't, that should have several mm of clearance. Something is off with your car.
                          • Mystikal
                            • 9602
                            #5443
                            That's a rear setup. On the front they would require 8-10mm spacers.
                            • mashpro
                              • Jun 2011
                              • 59
                              #5444
                              I have a set of Style 5's 17x8 et20 with adaptec 4x100 to 5x120 adapters that I want to run on my e30. What do I need to do to make this work and what tire size can I run?
                              • kreasims
                                • Jan 2009
                                • 149
                                #5445
                                Jay, need your advice....
                                Will 18x8.5/9.5 et 25 wheels fit E36 sedan? Recommended tyre sizes?
                                Thanks a million :)
