This is a sticky topic.
Big spacers - 30mm, and a load of fender work. Those wheels were just not made for E30s, sounds like Miata territory.Comment
I am trying to get more grip for autocrossing. I am currently running 205 50 15 and cannot get them hook up. They did fine until I put a Eaton M90 on the M20. Looking at running 17x9 and 17x10. The backspace is 6" on the 9" and 6 1/4" on the 10". I am also going to run bolt on flares. So my question is will the backspacing clear and how much should these stick out on a stock 87 325is. Also any ideas on tire width. I would like to use a 255 rear and 245 front.Comment
Not a chance. Even without spacers you won't have much space. 5mm can work, 10mm is pushing it.Comment
Mystikal,
i have BBS 16x7 et25 & 16x8 et12. what's right size (tire) & spacer to run these? i just want a stance/flush. :)
btw, my car late model w/ IE3,koni sport & drop hats. really appreciatedComment
195/45 F
205/45 R
That isn't "flush" but is a solid safe fitment. If you really want to push it:
20mm front spacers
5-10mm rear spacers (go as far you wish to venture with the roller)
Same rubber
Rolled rear fenders (may need a slight pull for the 10mm rear spacers)Comment
This isn't super urgent but, with fenders flared 2 inches, what would your recommended width/ offset and tire size be? I'd be running 15's and want a slightly undersized tire, on the widest wheel possible. Any suggestions?
Thanks!Comment
Will I run into any issues with an 87 325is H&R race, bilstein sports, Euroweaves with 205/50/15 tires?1987 325is Black/Black
-91k
-Stock (mostly)Comment
I've been half heartedly searching to find this but haven't come across it yet. Is there a chart or anything that tells what offsets fit e30's without spacers, and then which ones fit with spacers and the size spacer needed-and also a chart for which cars have the same centerbore as e30's?
Looking to see if 2004 Sentra's have the same centerbore as e30's (I believe sentra lugs are 4X114, but the wheels I'm looking at are drilled for both 4X114 and 4x100 and came off a 2004 Sentra) The wheels are 15X7 et35 ASA 5 spoke with a center cap with 195/60R15 Blizzaks.
ThanksComment
What is the widest tire i could realistically run on an ARC-8 17x8 on the rear- Fender lips are rolled, and spacers aren't out of the question.I don't always wreck cars, but when I do I wreck them into trees.
91' 318is S50 swap - The Black WidowComment
I have 205 50 16 DWS tires and I was thinking of pickcking up a staggerd set of ESM 002
s. My convertible is sitting on Bilstein Sport with H&R sport springs. How streched will the rears be? Is this worth doing? Can't afford new tires as I just bought these. Will they fit, will I have to roll the fenders. Anyone have pictures of this setup?
Thankssigpic
WTB-Strut BarComment
