17x8.5 et25 will they fit and what size tires? 235/40/17?
This is a sticky topic.
Not going as planned. Did a mock fitment without tires (just one), wheels did not rub, very close on the inside, but did not rub. Added tires and 3mm spacers for good measure, mounted on car. Headed out for my journey around the block. Made the first turn, got a smile, kept going, started the second turn and gggrrrrrrrinding started. Chewed off some of the lip. Bolts were still tight, removed and replaced, still hitting. Ran home, changed back to bottle cap, everything is fine. What the hell happened?
Notes:
Still waiting on hubcentric rings, but really don't think that's the problem.
15x8 et25
225/50/15 kumho ecsta
3mm spacers
stock lug boltssigpic
Streetable poly mounts, trans mounts are here!
http://www.r3vlimited.com/board/show...ght=streetable
'94 318i
'07 335i
'11 X5
'89 325ic m30b35Comment
Sorry I have another question:
I'm also looking to purchase 17x8 Apex ARC-8 et25 and I plan to run 20mm spacers to clear my BBK I have BC Racing coilovers and want to know if they will fit and what modifications are required for them to fit. Please let me know and what size tire can I run?
Btw the car is an 84Comment
Pro-tip: When asking in a thread full of pure, specific E30 fitment info don't suggest something completely different than recommended because some guy told you it works. If it works, I'd tell you.Comment
Jay, what's a decent tire in 205/50/16 that doesn't have a super tall sidewall? I've got 204/45 Federals right now, and I really don't like them much, plus it's getting close to tone for new tires. Along with that, I'd like to fill my wheel wells a tad more, but the 205/50 Feds I had on there before looked gargantuan. What do you recommend? The looks of a tire are important to me. Thanks!Comment
1989 325I Lowered on HR Sports with Bilstein Sports. Picked up a set of 4x100 to 5x120 18mm adapters. I have a couple of 5 series rims that I thought I could use, I added the 18mm instead of subtracting. So I am guessing they will be "Hella Flush" with a ET2? I am assuming most E36 rims will work, starting with around 40mm offset, then spacers netting about 20? Am I looking at this right?Comment
Notes:
15x8 et25
3mm spacers
stock lug boltsComment
'94 318i
'07 335i
'11 X5
