This is a sticky topic.
  • e30_302
    • Sep 2013
    • 453
    #7861
    Will someone double check me on fitting some Corvette wheels please? Don't want to make a mistake when having the adapters made. The wheels are 17x8.5" front and 9.5" rear, et56 for all. Will be running 255/40 tires on all four. I don't care at all about cutting up my fender (race car), just don't want to rub the strut or limit my steering angle too much.
    An online calculator I used says a final offset of 3mm will match the factory clearance on the inboard side. How does this sound? I know the rear has more inboard clearance, will the same adapter size I use up front work with the wider wheel in the back? Thanks!
    Car is an '87 E30 with H&R Race Springs and Bilstein Sports.
    • LIL REUP
      • Oct 2014
      • 3
      #7862
      I wanna put C5 or C4 corvette wheels on my '87 325is riding on coilovers, racelands.
      want these:
      pretty sure they're 17x8 in the front, 18x9.5 rear
      or sawblades/salad shooters, 16x7 front, 16x8.5 rear. don't quote me, not sure if i'm 100% accurate on wheel sizes lol.
      this is my car, Rosa:
      I know I need adapters/spacers, but what size for clearance? and I know I need rolled fenders.
      #REDCOUPESHAWTYsigpic
      • pandaiswong
        • Apr 2014
        • 112
        #7863
        I'm thinking about getting some Enkei 92's
        15x8 ET25
        About H&R race height, maybe slightly higher
        From what I've been reading I should be able to run 205/55/15 with 5mm spacers yes? Or would I have to go with 205/50/15?
        1992 Daihatsu Rocky SE
        1988 BMW 325 SETA
        • jamesheisch
          • Oct 2014
          • 2
          #7864
          Do BBS RM 012 wheels bolt right up?if not what should be the smallest spacer you can run? their specs are 15x6.5 et33.
          Thanks!
          • Mystikal
            Wheel Fitment Expert
            • 9602
            #7865
            Originally posted by Bullhead
            Will a 16x7.5 with an et25 fit these cars well Mystikal? And what tire would you recommend while keeping a 50 sidewall?
            Yes. 205/50
            • Mystikal
              • 9602
              #7866
              40mm front, 35mm rear adapters. Ideally.
              • Mystikal
                • 9602
                #7867
                want these:
                Can't answer without wheel offsets.
                • Mystikal
                  • 9602
                  #7868
                  15x8 ET25
                  Yes, 205/55 works fine with a 5mm front spacer only.
                  • Mystikal
                    • 9602
                    #7869
                    Thanks!
                    They bolt right up but are very sunken-in.
                    • e30lyf
                      • May 2007
                      • 4516
                      #7870
                      Hi Mystikal,
                      I have these wheels 16x8 et11 5x120 for my late model coupe. i am running E30 M3 5lug swap. koni sport with drop hats and IE3 springs. later on going GC full coilover set up.
                      what tire size do you recommend & maybe spacer? if i want to go staggered set up. how much more lip i can add and tire size. really appreciated
                      Thank you,
                      - Fercy -
                      Classic BMW Specialists
                      Santa Clarita, CA
                      www.BimmerHeads.com
                      • pandaiswong
                        • Apr 2014
                        • 112
                        #7871
                        Thanks man. Would it hurt to run 5mm spacers all around since I'll need to get hub rings anyway?
                        1988 BMW 325 SETA
                        • Mystikal
                          • 9602
                          #7872
                          Originally posted by e30lyf
                          Hi Mystikal,
                          Thank you,
                          They're already flush and need a stretched tire, so widening isn't an option. 205/45 and rolled fenders.
                          • Mystikal
                            • 9602
                            #7873
                            Spacers /= hubcentric rings. There's a chance of slight rubbing with 5mm rear spacers.
                            • Rickaytan
                              • Oct 2012
                              • 67
                              #7874
                              What spacer sizes would make 15x7 et26 sit flush? I have a late model 318i with 195/55 tires and it's slightly lowered on ground controls.
                              • Colby.325e
                                • Apr 2012
                                • 414
                                #7875
                                I don't know anything about wheels or tires and stuff. So I'll just show you a pic and see if you can "make my car look like this"
                                The general style discussion forum, as well as a place to post your car, or any car for that matter.
                                The wheels are
                                17x8.5 ET 20
                                17x10 ET 15
                                I've ordered Broadway Static coilovers which should be here soon. I want a faily aggressive setup. What tire sizes would you reccomend running on these offsets? Basically, I just want my wheels to fit exactly like this dude.
                                Any rolling / pulling?
                                Was gonna make an account on stance and ask the guy, but it's a thread from 2012.
                                1986 325e - RIP
                                1987 528e - Sold
                                1989 325iX - Parted Out
                                1991 318iS - Sold
                                1991 325iS - Current
