Originally posted by Mystikal
View Post
This is a sticky topic.
If I run 16x7.5 e31 turbine wheels et15 can I stuff a 245/50R16 tire and not rub. e34 chassis, car is quite low on coilovers. im convinced at least 15mm spacers will be needed
Turbo M42 Build Thread :Here
Ig:ryno_pzk
I like the tuna here.
Originally posted by lamboButtchug. The official poster child of r3v.
please help i want to buy 16x7 and 16x9 et33 they are bbs rs wheels and i need hub adapters cause they are 5x114. Will that work and if so what size tires do i need to get and how thick adapters do i need to get for the perfect fit. I am bagging the suspension in the near future. The tires on the rims right now are 195/45R16 all around.
Originally posted by E30s50vert View Postplease help i want to buy 16x7 and 16x9 et33 they are bbs rs wheels and i need hub adapters cause they are 5x114. Will that work and if so what size tires do i need to get and how thick adapters do i need to get for the perfect fit. I am bagging the suspension in the near future. The tires on the rims right now are 195/45R16 all around.
why not buy a filled and drilled set 4x100?
Hi Mystikal.. I am getting a set of 15x7 OZ Alpina's et12's to run with Bilstein HD's and H&R sport OE springs on an 86 e30. From what I've read these wheels should fit no problem, just wondering what the best tire size would be for best fitment and appearance, 205/55 or 195/55? Speedo is a little more accurate in the 205's but selection is better in the 195's...
Thanx very much.
Originally posted by Mike30e View PostHi Mystikal.. I am getting a set of 15x7 OZ Alpina's et12's to run with Bilstein HD's and H&R sport OE springs on an 86 e30. From what I've read these wheels should fit no problem, just wondering what the best tire size would be for best fitment and appearance, 205/55 or 195/55? Speedo is a little more accurate in the 205's but selection is better in the 195's...
Thanx very much.
I wana run 205/50s on a square set up of salad shooters. They are 16x8.5, et32. I went with a square set because I never really liked the look of staggered shooters the rear just always seems to poke too much causing the need for too much stretch IMO. Also its hip to be square.
Car will be on ground controls coils with 2'' taken out of the front struts and German engineering adjustables in the rear. Nice and high spring rates all around. I plan on rolling the fenders when I get the wheels on as well.
My question is what size adapters should I get to make these sit nice and flush with zero poke? I'm guessing 20mm adapters all around I just wanted to get some input before I pulled the trigger on them. Also I would love it these wouldn't rub like crazy, hopefully thats not a pipe dream.
Thanks.
17x8.5/9.5 Et13 all round, E30 M3 suspension, pre-fl car. Tyre / spacer suggestions?
Originally posted by Brezzi View PostI wana run 205/50s on a square set up of salad shooters. They are 16x8.5, et32. I went with a square set because I never really liked the look of staggered shooters the rear just always seems to poke too much causing the need for too much stretch IMO. Also its hip to be square.
Thanks.
