I am wondering what size tire to go with on my 15x8.5 in (ET33) BBS RM's. I am reconditioning a set of 15x 6.5's with a larger lip. My car is not very low, it is an H&R sport/Bilstein combo. I was thinking that a 225... would be the best bet right? any idea what height I should run?
This is a sticky topic.
Originally posted by EMRtek View PostI was wondering if 17x9 et 20 wheels all around would fit without any issues and what tire should I run... I don't mind running stretched tires. Thanks in advance.
Worst case scenario, you may need 3-5mm spacers for the front pair. Oh, and 215/40/17 tires are good, you'll need to roll the fenders too.
Jay
Originally posted by mattska View PostI am wondering what size tire to go with on my 15x8.5 in (ET33) BBS RM's. I am reconditioning a set of 15x 6.5's with a larger lip. My car is not very low, it is an H&R sport/Bilstein combo. I was thinking that a 225... would be the best bet right? any idea what height I should run?
At that spec, 225s are unrealistic. You're looking at 205/50/15 as the widest you're going to want to try to get on there. You will need to roll the fenders for this.
Jay
any thoughts mystical?
Originally posted by bobross View PostInterested in hearing some recommendations as to optimal final offset for my new wheels...
Fronts: 17x7.5
Rear: 17x9
I was thinking something around 27 up front and 22 out back. i'll be running a set of falcon 215/40/17's. Any thoughts?
Edit: Car is a late model with fenders pulled as much as my roller would allow :)
I have some 16x8 Forgelines, they are a 33 offset. I need to know what size spacers I should run front and rear. Front currently has a 1/4 inch spacer to clear the strut. Also, I need new tires and I don't really care for some of the 225/45's cause they look so huge.Is there any 225/45's that run kinda small? Or could I run a 215/40 or 215/45? My car is on Eibach's and Koni SA's. I believe the rear is rolled slightly already.sigpic
Originally posted by ZinnoE30 View PostI have some 16x8 Forgelines, they are a 33 offset. I need to know what size spacers I should run front and rear. Front currently has a 1/4 inch spacer to clear the strut. Also, I need new tires and I don't really care for some of the 225/45's cause they look so huge.Is there any 225/45's that run kinda small? Or could I run a 215/40 or 215/45? My car is on Eibach's and Koni SA's. I believe the rear is rolled slightly already.
Jay
Originally posted by Mystikal View PostSure, I gave them several posts up.
Jay
thanks for the thoughts!
Originally posted by Mystikal View Post15x8.5" RM's become ET8. You have to recalculate the offset when you widen them.
Jay
If i run a smaller lip, like a 1.5" do you think I will still need to roll the fenders? I would like to avoid doing this.
Originally posted by mattska View PostIf i run a smaller lip, like a 1.5" do you think I will still need to roll the fenders? I would like to avoid doing this.
15x7.5" ET20 (1.5" lip): 205/50/15 tires with no rolling
15x8.0" ET13 (2.0" lip): 195/55/15 tires with no rolling
Jay
Originally posted by Mystikal View PostWell, that depends on what you mean by 1.5" lip. Technically, a 1.5" outer piece will make the wheel 7.5" wide (the stock lip is 0.5", so 6.5" stock width + 1" of lip = 7.5"). I'll just answer both possible scenarios.
Jay
I see what you are saying. With the 2.5" shells the wheel is now 9" wide. I think I might get 1.5" shells for this set up. One last question, do you think with 15x7.5's i can get the 195/50 tire on...relatively easily? I have brand new 195/50's on my set of 15x6.5 RMs right now and I would rather not buy new tires if I don't have to. Thanks for all of your help.
-Matt
