This is a sticky topic.
  • MPLFoster
    • May 2013
    • 1490
    #8191
    Originally posted by Mystikal
    Wow took me forever to find your original post. Do me a favour next time and repeat what the setup is.
    No, that will rub in the back. What I said earlier was in regards to the rear mostly. +9 is way too low of an offset for a 8.5"/205/50.
    Sorry about that.
    So really, my only option for tires front and rear is 205/45 on a 16x8.5 +24 with 10mm spacers front and rear for clearance, making the offset +14 all around. Sound right? i apologize if im going in circles. offsets and tire sizing isn't something i have tons of experience with and im just trying to get as much tire under the car as possible while staying close to the original overall diameter.
    form.follows.function IG @mplfoster
    • mikebloco
      • Feb 2015
      • 190
      #8192
      I believe I read that the offset is et18
      So 16x9 4" lip et 18
      I was thinking of 225/40, just a little stretch so they tuck right but if I have to go with a lower profile I will. My car is stock height as well. Didn't want to lower it until I got the new wheels on.
      • Orbmvf
        • Apr 2015
        • 5
        #8193
        Looking to pick up some JNC031's as a quick fix. Looking to run 16s, was thinking staggered, 16x8 in the front and 16x?? In the back. Any guidance? I'm on OEM suspension but will be on H&R sports very soon after the wheels.
        • fanofe30s
          • 184
          #8194
          Would it be possible to fit a set of 205/50 tires on a 16x8 et 14 wheel with a slight fender roll? I know you would suggest 205/45 or 215/40, but it would save me the cost of buying another set of tires. Plus the grand touring all season tires selection is plentiful in 205/50.
          If not, would 195/50 or 195/55 work on that setup? Those seems to be other sizes that offers a good selection for the type of tires I'm looking for. Would it looked too stretched?
          H&R/bilstein sports
          Thanks again!
          Need a limited slip differential? Check my FS threads
          Feedback thread
          • Mystikal
            Wheel Fitment Expert
            • 9602
            #8195
            Originally posted by MPLFoster
            Sorry about that.
            Correct.
            • Mystikal
              • 9602
              #8196
              Bad offset for fronts. You ideally need an 8mm spacer to clear the front struts, but you will almost be guaranteed to have vibrations as they are not hubcentric at that size. So you'd run 10mm hubcentric spacers, but then the wheels (especially on a stock car) will be WAY outside of the car. And then you would have to deal with spacing the rears out to match, which at that point will require 205 tires, rolled fenders, and stiff springs.
              9" wide wheels are a huge undertaking.
              • Mystikal
                • 9602
                #8197
                Without available offsets I can't answer this.
                • Mystikal
                  • 9602
                  #8198
                  H&R/bilstein sports
                  Thanks again!
                  Should work with a flat fender roll. Maybe a slight rub occasionally. Right on that yes/no edge for me. If you have coilover it'll help massively. 195/50s would work 100%.
                  • Orbmvf
                    • Apr 2015
                    • 5
                    #8199
                    Et20. Offered in 16x8 and 16x9. http://www.jncwheels.com/jnc-wheel-collection/JNC031
                    • pietro
                      • Sep 2014
                      • 56
                      #8200
                      Yeah they do that when they start with E30-specific RS001s, but it's actually much better to start with a FWD RS application that sits the inner wheel edge right at the strut. That's how you get 9" and wider on an E30, by staying close to the inside.
                      This is really interesting.
                      Not quite sure how to ask this, but what's the stock E30 distance to watch on the inside? Seems like it's something like mounting pad to the strut? maybe less whatever clearance you need? Not sure how steering plays into that in front, or whether this distance would be different in the rear.
                      Coincidentally, I'm thinking about putting new 2" lips on a set of stock E30 RS 001s, which I think means that they go from ET25 to ET12, and 15x7 to 15x8.
                      I'm assuming stock RS 001s have 1" lips to start, then subtracting half the additional width (in mm) from the offset - 1 in is 25 mm, so ET25 - 12.5 = ET12(.5)
                      I think this leaves the stock clearance exactly the same, and just moves the outside lip a whole inch out.
                      Any idea if this will cause any fender clearance issues with no low and no roll on 205/55s?
                      I'm thinking that 205/55 would allow me to continue to use one of my bottle caps as a spare if needed.
                      • mikebloco
                        • Feb 2015
                        • 190
                        #8201
                        Well I guess I'll go with 8" wides in the front. If I have to roll the fenders then thats whats gotta happen. Thanks mystikal. What tire size do you recomend?
                        I found that the offset on the 16X9 rims are et20, and the offset on the 16x8 rim is et15.
                        • Mystikal
                          • 9602
                          #8202
                          Perfect. 205/45 front 225/40 rear is ideal. If you have trouble finding the rear size 215/45 works also.
                          • Mystikal
                            • 9602
                            #8203
                            The strut clearance (backspacing) varies depending on what struts are in the car as well as the diameter of the wheels. Because the strut is tilted slightly, the larger the wheel diameter the wider of a wheel/tire you can fit. 15x8 +12 is perfect, just run 205/50 tires and everything will fit great. 205/55s will rub a bit. That said this setup leaves a full 10mm of space towards the struts that could be filled with wheel. If you say started with 15x7 +35 RS's you would have a 15x8 +22 wheel that would fit 225 tires easily.
                            You can still use your stock diameter spare tire. If you're really far from home, have an LSD, and the flat is on the rear, just move the spare to the front and run the old front on the rear
                            • Mystikal
                              • 9602
                              #8204
                              Perfect offsets. 205/45 front and either 215/45 or 225/40 rears. Just need a rear fender roll for the 225s, otherwise nothing.
                              • mikebloco
                                • Feb 2015
                                • 190
                                #8205
                                I understand making the rear tire size a tad bigger but is it necessary. What about 205/50's on a et10 offset all around ?
