This is a sticky topic.
    Originally posted by zcenterb View Post
    I have one for you...
    Later tonight ill be buying a set of the e30 fitment Apex Arc-8's which are 17x8 with a 25 offset I believe. As far as tire fitment goes, I know 215/40r17's fit without fender rolling (correct me if I am wrong) but I was hoping to stuff 235/40's on all four corners. Was just curious on how much fender rolling would be required in the front and back to fit a 235/40 on a late model s50 e30 (sitting on the eibach race and bilstein B12 kit suspension). I always have the 215s to fall back on if it will require a ridiculous amount of rolling/pulling, but I love the grip of the 235s. Let me know, Thanks!
    Zach
    Just a basic roll front and rear is necessary. When I gave Apex those specs it was intentionally designed for 235/40s to fit with the least modification possible.
      So after reading tons of posts looks like the biggest I can run on a 17x9 + 25 rear is a 255/40 and that is with a good roll and probably rubbing? I am so screwed my car is essentially pointless right now :(
      I need like 265+ at this rate. Damn e30's
      Worlds 1st LS powered e30 cabby.
      Cab
      billac: 92 Lagunengrün cabriolet + cadillac LQ9 + Nitrous + rotiform SJC
      Raphael: 88 Lagunengrün IX + Hella 500's + Red ACS type 1's
      Shaggin Wagon
      : 01 325xiT 5 speed
      91 MR2 GT3076TS + E85 = 505whp + antilag = wheelies
      88 CRX OEM+ 42mpg DD.
        Jay...
        loving your z3 wheel porn on bf.c....I have a 2.8 coupe.
        for our e30's:
        Found some 15 x 8 et 20.....a new app for our cars..57.1/4 x 100 / et 20 ....
        I run R tires..225/50 15
        it seems like et 20 is desired, but man, based on my 15/7 et 25 Im assuming itwillbeatightfit?....I run about neg 3 camber up frt......neg 2.2 in rear...
        thanx
        JK
          Originally posted by Mystikal View Post
          205/45s. Fit perfect.
          Originally posted by 838Kelli View Post
          i got a 92 vert on ground control touring kit with modified strut housings. I looking for the best tire fitment without rolling my fenders with Borbet Type B staggered wheels. My biggest concern are the tire sizes in the rear which are 16x9 et 15. Thanks in advance.
          what you you recommend was what I was going to run in the front. Would it look funny using 205/45s all around on a staggered set up with? Thanks
            Hello I just saw this thread. I just got me a BBS RZ's fill and redrill from 5x120 to 4x100. I believe they are 16x8 et 23's. My car has stock suspension 1990 is, I put 205/45/16 at the rears while waiting for my 8mm spacers for the front to come, and I noticed the tires to be streched a lil bit and looked small. My question is how big a tire can i go with my stock suspension. what other options do I have on spacers...what size spacers on the rear since I have 8mm on the front. thanks.
              Ok so looks like 255/40 prob wont work. What about 245/40 looking at some federal ss595's cheap and sticky
              Cab
              Shaggin Wagon
              : 01 325xiT 5 speed
                hello
                  Yep. I'd probably go 17x9 +30 in the back.
                    Originally posted by JRKOUPE View Post
                    Jay...
                    for our e30's:
                    thanx
                    JK
                    Thanks man. That setup will require a good roll in the back, but should just work.
                      Up to you. The 205/45s fit well all around though. Problem with downsizing the fronts any more is that 195/45 is seriously short and leaves you with little ground clearance. 195/50 is taller than 205/45 and therefore looks even more weird. Just go 205/45 square.
                        You can fit 225/45s on the rears only. But if you put ANY rear spacer, it will no longer fit. I think those look best with 8-10mm spacers all around and 205/45s. You can also run 205/50s for a beefier look.
                          You're better off with 235/40 Federal 595-RS. Completely different tire than the 595 and extremely grippy. The 595s suck in comparison, and if you're talking about your car being useless on 255s I can't see why you would both downsize and cheap out on rubber.
                            Fit 16" staggered BBS RS ET45 on a 91' Vert
                            Hi,
                            I bought BBS Rs with special specs and I may need some help.
                            The specs are 16" 2x7,5 et45 and 2x8,5 et45 (staggered).
                            I would like to install them on a 91' vert with stock offset of et25.
                            Im not sure about spacers and tire Sizes i should get to be inside the wings and don't get strech tires.
                            Any help will be appreciate!
                            Thanks,
                            Karl
                              The RS isnt really that much more either, well played sir. To bad they dont make the RS in a 245. Any other cheapish under $110 245/17 you would recommend?
                              Cab
                              Shaggin Wagon
                              : 01 325xiT 5 speed
                                ASK ALL WHEEL/TIRE FITMENT QUESTIONS HERE - The Official Wheel/Tire Fitment T...
                                I just got the RSR in 205/45 and they suck balls compared to the falken 615k in the same size. Federals are also wider than most other tires. The federal 205 is almost a cm wider than the falken
                                Tldr: RSRs are cheap for a reason.
