This is a sticky topic.
  • Mystikal
    Wheel Fitment Expert
    • 9602
    #8356
    Originally posted by mbonanni
    16x8 et 23 18mmf/20mmr adapters with 205/50. On coilovers with camber plates in the front.
    Sent from my SM-N900P using Tapatalk
    Not even close. Rubbing everywhere.
    • PartyMarty
      • Jun 2015
      • 11
      #8357
      Why don't Beyern Mesh rims fit my IX???
      Why do the Beyern Mesh 17x7 4x100 ET27 rims fit the 325i and not the 325ix???
      Is it the struts? I'm getting a complete ground control coil over system for my ix so will that change the situation?
      I'm totally stuck on those rims so what do I need to do to make them work besides getting an i...or will the ground control conversion solve my problem?
      • spisio
        • Jul 2015
        • 4
        #8358
        Originally posted by Mystikal
        Ideally, 25mm. But they're heavy and expensive. 20mm all around is good.
        Great, thanks
        • CENTURION
          • May 2015
          • 372
          #8359
          H&r Sports/Billstains!!! with IX Euroweaves. 12 mm front 8 rear. if anyone was curious.
          • hexe30
            • Jun 2015
            • 141
            #8360
            Borbet Type A
            I've purchased a staggered set Borbet Type A (16x7.5 / 16x9) I'll be running catuned coilovers so I can adjust my ride height. Rear fenders are already rolled Looking for help with tire size and do not like the stretched look. I'm looking at:
            205/50/16 or 205/45/16 up front
            225/45/16 or 235/45/16 in rear
            Thoughts guys, 99% of my driving is on the streets and I'm not looking to be
            2" off the ground. The car is just a play toy. Don't know if it makes a difference but I have a s50 swap as well
            • Mystikal
              • 9602
              #8361
              They definitely fit. No mods necessary. Use 205/40s to ensure no rubbing.
              • Mystikal
                • 9602
                #8362
                Need the offsets.
                • VitalkaE30
                  • Aug 2012
                  • 238
                  #8363
                  Hey, I'm about to purchase a set of wheels for my 89 coupe and wanted to see if they will fit. 17x9 et20 front, 17x10 et20 rear and the other set is 17x9 et33 and 17x10 et33. Rear fenders are pulled and shaved. What are my options? Thanks
                  • Mystikal
                    • 9602
                    #8364
                    With a lot of stretch they can work. First set needs 5-8mm front spacers. Second set 20mm front 12mm rear. Ideal tires are 205/40 225/35 staggered.
                    • 89DelphinE30
                      • 287
                      #8365
                      Looking into some wheels wondering if these would be able to fit an E30?
                      Specs: 16x8.5
                      +22 offset all around (square setup).
                      Thanks!
                      • spisio
                        • Jul 2015
                        • 4
                        #8366
                        Back again. (1991 BMW 318is, stock suspension)
                        Looking at a set of MiM 1900 15" x 7" et13 4x100. What wheels would work with that offset?
                        Thanks in advance!
                        • Mystikal
                          • 9602
                          #8367
                          Specs: 16x8.5
                          Thanks!
                          You need 5mm front spacers to clear the struts. Otherwise good to go. 205/50 should just barely clear without rubbing. 225/45s will require a fender roll, and front camber plates for a little extra tilt.
                          • Mystikal
                            • 9602
                            #8368
                            Thanks in advance!
                            Porbbaly mean tires, right? 205/55s should just clear at that offset. 205/50s work also.
                            • spisio
                              • Jul 2015
                              • 4
                              #8369
                              Ack, ya... thanks
                              • hexe30
                                • Jun 2015
                                • 141
                                #8370
                                Need the offsets.
                                16x7.5+20 front
                                16x9+15 rear
                                Like the tires to be square as possible.
