Originally posted by Gooneric
View Post
This is a sticky topic.
Originally posted by Luke_M View PostOk, cool. I'm using bilstein sports and I cut the bumpstops down by about 1.5" so I thought that was ruled out. I guess I was wrong. Thanks for the advice!
Originally posted by red325ix View PostI have a set of DSII's from an e36 M3 that I'd like to try to get on my e30.
17x7.5 et41 front
17x8.5 et41 rear
I'll need adapters as I'm not converting to 5 lug. Should I get the thinnest @ 18mm and 20mm?
What would be the optimal tire size if I could make these fit.
My car is lowered pretty low on GC coilovers.
215/40 F 235/40 R
or
30mm adapters
195/40 F 205/40 R
Originally posted by InNeedOfBoost View PostI wasn't asking a fitment question, I was asking what's a good tire and where to find said tire in a 225/45-16.
Originally posted by Mystikal View PostNow, this thread is open to all questions regarding fitment of wheels/tires. Discussion of "what tire should I buy?" or "what colour should I spray paint my 18 year old bottlecaps" will be deleted or otherwise moved from the thread. Fitment questions only. Note: answers may include tire recommendations in that particular size, but please no direct questions regarding tire choice.
16x8 tire question
going with 5 lug setup, will be running 16x8 style 5 from e38.
1997 e36 m3 front knuckles and 318ti rear subframe and arms.
I would not like to run skinny tires, what is the widest i can mount on the front and rear?
I have access to a fender roller if i needed to.
Thanks in advance.
Originally posted by 5ickride View PostWhat recommendations do you have for 16x7.5 (f) and 16x9 (R) Borbet B on a KW V1 coilover suspension? I would like to have some cushion (meat) if possible.
Thank youOriginally posted by 5ickride View PostThat would help...et15 (offset)
Originally posted by boriksh View Postgoing with 5 lug setup, will be running 16x8 style 5 from e38.
Thanks in advance.
Originally posted by asuj158 View Postnew question (cant believe you still answer all of our questions daily lol) 17x9 et20 WITH KAmotors flares (ultra wides extra 2.5" clearance back and 1.9 front) widest tires i can fit?
17x9 clears the struts at +15, so you'll need a small spacer on the fronts.
