This is a sticky topic.
    Originally posted by mikebloco View Post
    Well I guess I'll go with 8" wides in the front. If I have to roll the fenders then thats whats gotta happen. Thanks mystikal. What tire size do you recomend?
    I found that the offset on the 16X9 rims are et20, and the offset on the 16x8 rim is et15.
    Perfect offsets. 205/45 front and either 215/45 or 225/40 rears. Just need a rear fender roll for the 225s, otherwise nothing.
      I understand making the rear tire size a tad bigger but is it necessary. What about 205/50's on a et10 offset all around ?
        Think I could fit 225/50/16s on a 16x9 et 15 under a late model vert with some rolling? Having trouble finding decent 225/45/16s.
        Thanks in advance!
        1987 325i-M60b44 swap
          Dude 225/45 direzza Z2's^
            Too low of an offset to run a stock diameter tire. 205/45s would be perfect.
              Thanks in advance!
              Nailed it. Also check onlinetires.com for all oddball sizes they tend to have weird shit.
                Dude. You rock. If only they made Z2's in 205/45. At least I still have the Z1's to play with
                  16x8.5 et+14 (originally +24) all around with 10mm spacers. 205/45R16 all around.
                  Car is a late model coupe on the GroundControl coilover conversion kit so it wont be slammed.
                  Can you tell me what my clearances will be? Will i run into any wheel/tire travel issues with the arches?
                  form.follows.function IG @mplfoster
                    Haha thanks. I'm in the same boat, running a discontinued (265/40/17) Z1 SS size. When they're finally dead I'll have to downsize a bit. Womp womp.
                      Just need a rear fender roll. Tight but safe. There's a small range of what I call "perfect fitment" and those land right in the middle.
                        You're the man, man. Thanks again for all the help. :)
                          Yeah I changed routes going with 16x8's all around et10 offset. 5mm spacer in the front and 3mm in the back. I'll probably go with H&R super sports springs still debating on the race springs. Whenever I get them I'll just phone book the fenders ahaha.
                            Perfect. 205/45 front 225/40 rear is ideal. If you have trouble finding the rear size 215/45 works also.
                            Oops so the 16x8's will be et25. The 16x9's will be et15. Aside from spacers will I run into any other issues?
                              Quote:
                              Originally Posted by essi1553 View Post
                              My brain melted after 32 pages...
                              Can I get a set of 15x7.5 with a 32 offset to fit my 89 325i lowered on h&r race springs?
                              I don't mind spacers but fender rolling is out of the question.
                              (tire size is 195/50/15)
                              Depends on the thickness of the sidewall protector on the tire. I'd say you have a 50/50 shot, but even if it cleared it would be by a hair.
                              Cheap safe choice: 3mm front spacers, keep everything else
                              Better safe choice: 15mm spacers and extended bolts all around
                              This pretty much answers my question, but I'd like to run at least a 205 wide tire. I'm looking to buy a set of Konig Rollers - same specs as essi1553.
                              Just a matter of more wheel spacer?
                              1989 325i Lachssilber Sedan
                              5-Speed Swapped
                              M30B35 Swapped
                              MegaSquirt MS3X
                              1987 325i Lachssilber Sedan
                              260k OEM Automatic Daily Baby
                                Any tire recommendations brand wise for 16x8/16x9, very limited selection in 205/45, 215/45, or 225/40/16 the sizes that were recommended before.
