	This is a sticky topic.
 So I rethought things and went 16X8 et20 wheels and was thinking 16/45/225 all round. Have a buddy with roller. And plan on painting the car so I'm not too worried about that. Is it possible? If so how hard. I hate to just ask here but there are just too many pages too look through haha.1990 S50 Calypso-rot 325iComment
 Because of the shape of the arm a larger diameter wheel has more space in an E30 (front and rear). I've seen 16x9 ET25 as the most aggressive inside rear fitment in a 16" that worked. I believe there is still some space to go but haven't seen anyone do it.Hey, weird question here, but I'm wondering about the highest offset you can run in the back without touching the trailing arm. I'm trying to fit maximum width under the rear of my widebody and need to know how far I can go in.
 I just need to know width and offset for what you've tried and I can convert the numbers from there. For example, will a 16x10 ET25 clear the TA?
 TIAComment
 16x8 is beautiful at +12 to +22. The lower in that range the better poke you will have. No rub with 205/45/16 tires.Comment
 Super common setup. Works with a roll and a non-slammed height.So I rethought things and went 16X8 et20 wheels and was thinking 16/45/225 all round. Have a buddy with roller. And plan on painting the car so I'm not too worried about that. Is it possible? If so how hard. I hate to just ask here but there are just too many pages too look through haha.Comment
 Purchased a set of 16x8 et25 wheels, have 205/50 Michelin Pilot's... Going to be running a 10mm spacer to start front and back (stock wheels had spacers and longer wheel bolts, didn't think to buy shorter wheel bolts)
 How would this set up be? Would it be more ideal to remove the spacers and just have the 16x8 et25 wheels on front and rear?
 I'm currently lowered about 1.6-1.8 inches.
 Thank you!!2016 F-150
 1987 Royalblau 325es B25 turbocharged
 Build thread here: http://www.r3vlimited.com/board/showthread.php?t=405594Comment
 That's 16x8 effective et 15. Should be good. I'd be very surprised if the fronts would clear the strut without the spacer. Are your fenders rolled?Purchased a set of 16x8 et25 wheels, have 205/50 Michelin Pilot's... Going to be running a 10mm spacer to start front and back (stock wheels had spacers and longer wheel bolts, didn't think to buy shorter wheel bolts)
 Thank you!!-Christian
 '37 Chevy pickup, the über project Originally posted by roguetoasterBe sure to remind them that the M42 is one of the best engines ever made, but be sure to not mention where it actually falls on that list. Originally posted by roguetoasterBe sure to remind them that the M42 is one of the best engines ever made, but be sure to not mention where it actually falls on that list.Comment
 Negative fenders are not rolled. Think they will need to be? I don't know my exact drop, was about to the 1-2 finger wheel gap on the stock bottle caps with 205/60/14 (Setup going on is about .40 higher)2016 F-150
 Hey! I'm sure this has already been answered. Buy can't seem to find it. I'm looking o get 17x8.5 inch bbs reps with et25 offset. Will this work/rub/stick out too far? My 1989 325i vert has h&r sport springs. What tire ize should i also be getting?. 215/45 r 17? I wanna get rid of some wheel gap. Thanks!Comment
 Okay thanks. My theoretical setup would be 10mm closer to the trailing arm so I'm not sure how well that'll work... 16x11" ET 10 is the setup in question and would sit pretty much flush at the fender edge with my current setup of 16x9 ET -15.1990 325i Touring - The Bonsai Bimmer - Patiently Waiting
 1984 316 Coupe - The Base Model - Pain in the Ass
 1988 750iL - The Daily Driver
 ...And a couple others...Comment
 Im planning on buying 16x8 XXR wheels, 0+ offset, 4x100. I was planning on running 205/45/16, 215/50/16, or 225/45/16 tires. Which would work best, or fit best on my 1988 325i??Comment
