	This is a sticky topic.
 E86 ///M Coupe - Imola Red/Imola Red
 E90 330xi - Titanium Silver/Black
 K46 S1000RR - Matte Red
 Follow the E30 Build thread http://www.r3vlimited.com/board/showthread.php?t=395205
 I'm doing a little bit of wheel shopping for next summer and I'm stuck between Kosei K2Rs in 15x7 in ET25 or TRMotorsport C1s in 15x7 ET25.
 Would I need to run any spacers or would I be good to go without any rubbing? I'm only slightly lowered on H&R Sports if that helps at all. I'm open to different tire sizes too. "Leafeon" '92 Lagunengrun 325i Vert (Daily Driver/Project) "Leafeon" '92 Lagunengrun 325i Vert (Daily Driver/Project)
 http://www.r3vlimited.com/board/showthread.php?t=366044
 The stickers make it go faster. :nice:Comment
 Hey Mystikal
 Have read through this thread and couldn't find a definitive answer so thought I'd ask as well
 I've got a cabrio, with coilovers, and wondering what size tyres I'd need to get wheels to sit flush. Guards will be rolled.
 The wheels are:
 17x8 +30
 17x9 +22
 Not sure if I need spacers either?
 Thanks in advance
 edit* - worked out that 235/40 with 5mm spacer are perfect for fronts, would 215/40 also be reasonable if I want a bit of stretch?
 edit2 - 215/40 all around, 5mm spacer up front, fenders rolled, car dumped as low a possible. How's that sound for a flush setup?Last edited by nosh; 10-24-2016, 04:52 PM.Comment
 Man, that's so cool. Using OE parts as upgrades just does it for me way more than any aftermarket stuff, regardless of the price tag. Can't wait to see how it turns out.Comment
 Nothing needed, those fit perfect. 205/50, 205/55, 225/50, 225/45 all fit fine.I'm doing a little bit of wheel shopping for next summer and I'm stuck between Kosei K2Rs in 15x7 in ET25 or TRMotorsport C1s in 15x7 ET25.
 Would I need to run any spacers or would I be good to go without any rubbing? I'm only slightly lowered on H&R Sports if that helps at all. I'm open to different tire sizes too.Comment
 Haha reading this was a satisfying roller coaster. Yes, you figured out exactly what I would recommend. 215/40 square, 5mm front spacers to clear the struts. There are some VERY reasonably priced 57.1mm 5mm 4x100 hubcentric spacers on eBay (I just bought a ton of them).Hey Mystikal
 The wheels are:
 17x8 +30
 17x9 +22
 Thanks in advance
 edit2 - 215/40 all around, 5mm spacer up front, fenders rolled, car dumped as low a possible. How's that sound for a flush setup?Comment
 Haha it was all thanks to you, and yeap, I'll find spacers on eBayHaha reading this was a satisfying roller coaster. Yes, you figured out exactly what I would recommend. 215/40 square, 5mm front spacers to clear the struts. There are some VERY reasonably priced 57.1mm 5mm 4x100 hubcentric spacers on eBay (I just bought a ton of them).Comment
 Thanks for the response! I ended up doing a little more research and found a really nice set of BBS RS 003s - 16x7 ET25 4x100.
 In your recent response to sfe30stoner for his 16x7 ET20 on HR/Sport & Billy HDs you said he could run 205/50-16 max. Your "penultimate" setup is the look/feel I am going for, just 16s vs. 15s. I have seen mixed results with some people saying I can run 225s and others saying 205s. Will my larger offset of et25, over sfe30stoner's 16x7 et20, allow me to run 225/45-16s front and back? Or do I need to stick with 205/50-16s?OE? Style 10s or 15" Basketweaves all day. They're both 15x7 +24 and can fit 225 rubber without any problems.
 I personally run 15x7 +20 BBS RZ's with 225/50 tires on my 325iS. I went through tons of wheel setups before I settled on those. Bought them in 2006 and haven't touched them since, they're too perfect for the car. Like factory 15" basketweaves with a massive lip injection. That's my penultimate.
 One of your post on MaxBimmer thread says that 15x7.5 with a ET18.65 is the max wheel size within the fender. One reply notes that 225/50s will fit on 15x7 et25 and 15x7.5 et19. Does this still apply to 16in wheels and allow 225/45-16s on 16x7?
 Bottom Line.....
 1) Max Tire Size for 16x7 ET25 = 225/45-16s or 205/50-16s?
 2) Would either tire size benefit from a spacer for a more flush look without rolling the fenders?
 1990 325is
 BavAuto springs
 Bilstein Sport shocks
 Might switch over to Bilstiens with HR Race or Sports
 Leading Tire Choices:
 225/45s - Dunlop Direzza ZII Star Spec 225/45-16s
 205/50s BFGoodrich g-Force Sport COMP-2 or Bridgestone Potenza RE760 Sport
 There are definitely more options in the 205/50 over the 225/45s. This is a weekend driver, so I am planning on high performance summer tires.
 Here are the ones I am picking up tomorrow!
 I have an 89 325i sedan. It is running H&R Springs and Konis. I would like to go to a 15" wheel, and preferably something that can be bolted up and go without messing with things.
 I was wondering about something like the following:
 15" Rondell 58
 4x100 7J ET35
 If I ran a a 205/50 tire would these work on my car without spacers/fender rolling? These seem to have a higher offset than some of the other wheels I was considering so I was hoping for some advice from those who are more experienced with wheel tire fitment on E30's.
 Thanks!Comment
