This is a sticky topic.
    I just saw the work equip 40s.
    Would anyone be able to help with choosing the appropriate offset in 15x8/15x9 size?
    Link to the spec sheet --> http://www.work-wheels.com.au/files/pdf/equip-40.pdf
    Also would you think I would be able to run a bbk if I went the standard or big brake barrel choice?
      Setup: Koni SA, ie3 race springs, e90 hats, gc sport camber plates.
      Desired wheel: 15x8 et20 all corners (trm c1)
      Question: What’s a good tire size that won’t rub? 215/45/15? 225? 50? Also, will I need spacers and if so, what size? Thanks!
      1990 325i Coupe
      ///PNW e30 CREW
        Is 16x8 et7 all around too aggressive? I’ll be running 215/45/16 tires with a slight roll all around.
        Original wheel is 16x8 et32 but will be running a 25mm adapter
        Suspension: coilovers
          Beyern mesh
          I really like the Beyern mesh style wheels and I have them on my ‘89. They were on the car when I got it.
          My son wants them on his ‘87. They are 15x7 and both the cars are stock suspension.
          Are all the Beyern mesh wheels the same offset/backspace?
          Can we go up to a 16”? Or, are there 15x7.5 or 8?
          I’m not finding any info really, from what I can tell if you want a Beyern mesh you don’t get to pick and choose between different widths?
          My son has the 1987 325e, 2 door, 5speed
          I daily the 1989 325i, 4 door, 5speed
            Looking at a set of e38 style 5s with 205/50 tires, can i use adapters or do they have to be filled and drilled?
              With 205 you can use adapters, although they will be pretty aggressive at ET5
                Okay thank you!
                  Late e30 5 lug swapped on coilovers: front e36 m3/rear 318ti
                  Style 32's 8"x17" et20,
                  Can I get away with 215/35 tires, don't like to stretch too much?? If someone has pics would greatly appreciate...
                  Also,
                  Style 23's M-Contours 8.5"x17" et41 all around, which spacers, tires and studs length recommended?
                  Thanks in advance!
                    Also,
                    Thanks in advance!
                    bump, anybody?
                      C'mon gurus, I'm sure somebody has at least attempted to try this^^^
                      Please chime in, I've browsed through 200+ pages but just too much too read here lol
                        Staggered Style 18
                        I have a shot at some cheap Style 18s on CL. $200 asking.
                        17x7 front and 17x7.5 rear, all are ET41.
                        If I get them I'll probably get 4-5 lug 18mm adapters. I tried looking for pix of these wheels mounted on an E30 but I'm not finding any. Is there a reason these wheels wouldn't work on an E30 with spacers?
                        Car is a stock height 92 cabrio that has an M30 swap.
                        Thanks!
                          New combo
                          16x8 style 5 off 90’s 7 series. H&Rcup kit. Wanna go to either a 205/40/16 or 205 45 16. Will I need to roll my fenders?
                          1989 325ix(sold)
                          1989 325i sedan s52 powa (current)
                            I’m running them right now drilled and filled no spacers and 225/45r17. Those two sizes you put are way small. If you want to run a 205 you should go 50 series.
                              Also,
                              Thanks in advance!
                              Bump
                                The gods have left the building...
