BBS Garage: All things BBS
This is a sticky topic.
  • Mike36
    • 1079
    #1096
    Right before I mounted them :)
    • bradnic
      • Jul 2012
      • 3551
      #1097
      NICE.. THANKS for posting the pics!!
      tire sizes? spacers?
      assume you had to roll the fenders and quarters for that flush fit?
      HOWTOs:
      DB vert plastic bumpers
      OEM Keys
      MTech1 docs
      88 ix Lach/Card
      91 ic Calypso 3.1
      86 Cosmo 2.7
      OEM+ or bust!
      • Mike36
        • 1079
        #1098
        16x8 ET14 195/50/16
        16x9 ET14 205/50/16
        So I'm not running any spacers as that would just push out the wheels. Tire sizes are a bit tall compared to what other people run but those are all I had at the moment and they have decent tread on them. I'll probably go with 205/45/16 front and 225/45/16 rear next time. Fronts actually fit without any rolling, the rears needed a slight roll, and by "slight" I mean only needed 2mm's of clearance. I did however give them a full roll so I can run beefier tires down the road.
        This photo is the rear fitment.
        • Mike36
          • 1079
          #1099
          Another rear.
          • drumsauce
            • Jan 2017
            • 15
            #1100
            BBS RS waffle help
            Hello BSS Yodas! BBS RS nube here. Need your wisdom...
            I got this set of 4 16" BBS RS's at an incredible deal ($500!)
            For my project
            But I'm missing a centercap. The part number for the waffle is "09.24.028" but I haven't found a matching cap with that part number on CL or Ebay.
            Question: Can I use another part numbers for the waffles? (Searched but couldn't find a definitive answer about part numbers)
            Please advise.
            Cheers!
            • Zeemz
              • 485
              #1101
              Last year I found some BBS RS003 somewhat local so I went for it. Before I bought these I had been planning on buying some Nogaro Silver Euro Weaves so I decided to restore the RSs in a similar fashion.
              They were in really great condition, so I decided to refinish the stock lips and not spend more on wider lips.
              Refinish Process
              A little color
              Refinish the bolts in silver or black?
              Black won
              I think Dave's work, from Renewed Finishes, speaks for itself they came out amazing. https://www.instagram.com/renewedfinishes/
              BBS RS003s 16x7 ET25
              Original Lips and Hexs Brushed and clear powdered
              Centers and Waffles - Nogaro Silver & clear powdered
              Bolts and Barrels in Satin Black Powder
              Wheel/Tire/Suspension
              BBS RS003s - 16x7 ET25
              Dunlop Direzza ZII Star Specs 225/45R16s
              H&R Sports, Bilstein Sports, E90 Drop Hats, M3 Offset CABs
              1989 325is Lachssilber - Sold
              1990 325is Sterlingsilber - Current Project
              September 2018 Car of the Month: Zeemz
              Youtube Track & Autocross Videos
              • bradnic
                • Jul 2012
                • 3551
                #1102
                Nogaro BBS = WIN
                HOWTOs:
                OEM Keys
                MTech1 docs
                88 ix Lach/Card
                91 ic Calypso 3.1
                86 Cosmo 2.7
                OEM+ or bust!
                • Mfever
                  • May 2007
                  • 1058
                  #1103
                  Is the brushed look similar to the stock machined lip? Just got a set if RS211’s that need refinishing but I want the lips to have stock machined look and clear coat!! Hoping that its possible!
                  • getouth
                    • Jan 2010
                    • 3343
                    #1104
                    That will get you pretty close to stock. I recommend a satin clear... not too glossy for the stock finish.
                    FEEDBACK:
                    http://www.r3vlimited.com/board/showthread.php?t=316212
                    BMWCCA #398608
                    IG @yagayo38
                    "The Best E30's were built with two camshafts four cylinders and sixteen valves!".
                    • Ceeker
                      • Sep 2009
                      • 2821
                      #1105
                      Does anyone have the torque spec for the metal valve stem? I have BBS Rms. thanks
                      • Staszek
                        • 2533
                        #1106
                        Question for all your BBS experts, which faces are the largest faces for the 17" wheels, basically the 13" center for the RS. My main problem when I had 16's was it had the 12.25 face and the bolts rubbed against my BBK even though the wheels cleared, so I had to space them further out. I know they made a 13" face but dont know which models those are.
                        • Mike36
                          • 1079
                          #1107
                          • Staszek
                            • 2533
                            #1108
                            Originally posted by Mike36
                            I have seen that list, so I am to assume if it says 17" it has the 13" face unless it says otherwise?
                            • Mike36
                              • 1079
                              #1109
                              Yes, but double check the last column. It may say "16" center (doublestep)" which means that it is a double stepped 16" face.
                              • E30CanadaVert
                                • Jun 2019
                                • 19
                                #1110
                                Having an issue with the BBS RM012. When the technician fitted the wheel onto the hub of my cabrio he said there was lots of play. Aren't these wheels and the car hub both 57.1mm? Any help is appreciated!
