IAA gamble
  • Al_g
    • Nov 2022
    • 4
    IAA gamble
    I rolled the dice on a non running/driving e30 at IAA. The hood was listed as stuck so I thought maybe the hood release was broke and it just needed a jump. In my defense I buy wrecks and that is often the case.
    Upon arrival the hood release was indeed broke so I was hopeful. I used the grille backup release and voila. There was a missing cylinder head. After further inspection the rear diff and complete exhaust is missing. The cylinder walls are a bit rusty but I don’t see any damage. Luckily it’s a manual car and pretty much rust free.
    The initial plan was to do a complete paint job and turbo it this winter. Obviously plans changed and I’m trying to find the most cost effective solution to get this thing going. Finding a reasonable priced parts/parts car in northern Vermont is near impossible.
    My question for you guys is, would it be a bad idea to just put a used head on this given the unknowns? Or should I just look for a complete running engine?
  • AWDBOB
    hooptie connoisseur
    • Aug 2013
    • 4508
    I did an engine for a guy a few years ago that did almost that exact thing (engine sat with head off, light corrosion on bores, he put a head on it). He wasted a ton of time trying to get the car running with subpar compression, and in the end, had me swap a new shortblock in.
    But, it's impossible to say for sure what to do without pics of the rusty bores, and of your GF.
    • Al_g
      • Nov 2022
      • 4
      • 2mAn
        Señior Mod
        • 21040
        QFT
        The success of this job really depends on the hotness of your GF.
        If she falls in the 8-10 range in the hotness scale then you might be in trouble.
        Let us help you. Post pics of your GF
        Simon
        Current Cars:
        -1966 Blue Boat
        -1969 Red VW
        -1986 White BMW
        -2006 Green Thing
        Make R3V Great Again -2020
        • 2mAn
          Señior Mod
          • 21040
          Ok, before we scare new blood away from our forum it looks like someone robbed the 87-IS of its 885 head and 3.73 to probably spruce up an eta. Can’t blame them for it, but you got yourself a decent looking car. I’d swap in a good used long block, and find a diff with a ratio that’s better suited to your turbo plans, like a 3.25 or maybe. 2.93 depending on how wild the plan is. Then while the car is driving you can build the block you took out.
          Welcome to r3v where we love E30s and your GF
          Simon
          Current Cars:
          -1966 Blue Boat
          -1969 Red VW
          -1986 White BMW
          -2006 Green Thing
          • ForcedFirebird
            • Feb 2007
            • 8300
            It's junk. You should ship it to 33069 for proper care ;)
            john@m20guru.com
            Links:
            • jbontke
              • Mar 2019
              • 449
              I like this place.
              • 2mAn
                Señior Mod
                • 21040
                Al_g Did we lose you?
                Simon
                Current Cars:
                -1966 Blue Boat
                -1969 Red VW
                -1986 White BMW
                -2006 Green Thing
                • Al_g
                  • Nov 2022
                  • 4
                  Negative, well sort of…
                  • 2mAn
                    Señior Mod
                    • 21040
                    Well, hang in there. You got a good start, if you’re not in a rush what you’re looking for can pop up.
                    Not the turbo ratios you’d want, but....
                    Simon
                    Current Cars:
                    -1966 Blue Boat
                    -1969 Red VW
                    -1986 White BMW
                    -2006 Green Thing
                    • decay
                      • 5637
                      since you're missing a diff, i can't recommend the torsen unit out of a Z3 strongly enough. avallable in a few ratios, but all of those were paired with a 1:1 5th ZF transmission in manual cars so they're mostly turbo-friendly. (i did manage to hunt down a 4.10 torsen when building a high-strung ITB'd M42 car, but i had to find a junkyard auto Z3 to source.)
                      ratios here: http://www.unofficialbmw.com/phpBB/v...ic.php?t=32354 but doublecheck with the seller as to what you're buying by asking for a picture of the ratio tag. if you aren't already familiar with this site, start your parts search here http://car-part.com/
                      best solution for a street car. race car, maybe not, but that's because they become open if your spring rates are stiff enough to lift the inside rear wheel off the ground.
                      my current project came with one out of the box (it's a z3 2.5i manual) but when i swapped one into that 318i and drove it home from my buddy's shop where he let me work on my car for cheap, it started raining and of course i had to discover how well it actually worked waiting at a freeway onramp. i clutch-dropped it to make it to 80mph los angeles freeway speeds and i could feel it hunting back and forth for traction, wiggling the rear end a little like miley cyrus twerking, but it stayed straight and put the power down even in the wet.
                      gear oil is 75W90. redline's my favorite but pick your poison. change that right away and then beat on it like it owes you money because there are no clutch packs to wear out.
                      welcome to the party.
                      past:
                      1989 325is (learner shitbox)
                      1986 325e (turbo dorito)
                      1991 318ic (5-lug ITB)
                      1985 323i baur
                      current:
