Best shifter option for m10?
  • moatilliatta
    • 6149
    I wouldn't run 95% of the chassis mounted shifters out there. I wouldn't run any chassis mounted shifter unless your running Poly or hard rubber mounts. Auto solutions makes a IMO the best shifter while keeping the stock shift console.
    @Zakspeed_US
    • decay
      • 5637
      as i said, the reason mine is on the shelf is i don't have poly engine/trans mounts yet.
      past:
      1989 325is (learner shitbox)
      1986 325e (turbo dorito)
      1991 318ic (5-lug ITB)
      1985 323i baur
      current:
      • randomInteger
        • Aug 2021
        • 127
        I recently rebuilt my shifting mechanism (metal plate), stock all around, every single wearable item replaced. While it shifts like butter (easiest shifting and feel) its like a mile long for each shift. Must be good 5-7 inches of travel between 1-2, 2-4, etc. Ive swayed away from chasis mounted shifter due to online critique. My ideal set up would be a short shifter(z3) and a dssr (reached out to multiple vendors, not one will produce it anymore). I started a few threads in the m10 forum but no luck.
        Theres also this, adjustable short shifter with no need to split the ball cup. https://www.iemotorsport.com/product...t-e30-e24-e28/
        PS. please differentiate in your post which shifter mechanism you are referring to, as people with the g240 without the ears are limited in their options. Similarily the non metal plate version can confuse people on both ends.
        1984 318i Coupe 66k
        • It's Soda Not Pop
          • Jan 2022
          • 877
          I've had a chassis mount for 3 years zero issues. I do however have delrin everything. I beat this car in the mountains and no issues.
          88' Seta 2.7i Zinno
          https://www.r3vlimited.com/board/for...430-my-88-seta
          • hozzziii
            • Feb 2019
            • 170
            Well, why not buy the z3 shifter and make the dssr yourself or have a decent welder do it?
            I mean, it's just a steel rod with four plates on each end with holes in them.
            You can buy the pin and clips from anyone that sells a kit, just don't buy the kit, buy the hardware and make the rod yourself.
            I mean I don't have experience but I've seen people make them on yt and it seems like a simple enough piece.
            • randomInteger
              • Aug 2021
              • 127
              for sure, thats one viable route. One day when the world slows down hah.
              In the mean time, if anyone reading this has a spare dssr for the m10 g240/5 drivetrain, hit me up.
              1984 318i Coupe 66k
              • Holland
                • Nov 2008
                • 7212
                I had a Z3M in my car when it had the M10. It's doable, but you have to bend it to match the shape of the E30 shifter. Also it did just rub on the driveshaft, so I had to bend the rear tab for the sheet metal shifter console up to clear said driveshaft. In case you decided this route, it is possible. Oh, and I did bend my selector rod for smoother shifts.
                Originally posted by DEV0 E30
