E30 early vs late windscreen rubber gasket
  • Liffa
    • May 2025
    • 16
    Hi!
    I have a pre facelift e30 coupe. I need a new windscreen gasket and someone is selling a new one with oem number 51311972248 for a good price. Looking at the oem number it says this one is for facelift models, however I cant find any information saying the windscreens are different between the years. Does anyone here know if this gasket will fit my car? Thanks
  • uturn
    • Dec 2010
    • 1005
    Per RealOEM.... 51311913887 is superseded by 51311972248.
    The difference looks like later cars with airbags used part number 51311962985. Hopefully someone else can clear things up.
    • Vincenze
      • Apr 2019
      • 1031
      The late window lockstrip is black while the early one was chrome.
      The late one may be a little bit wider.
      Isn't this what you need? It's cheaper than the late one.
      URO makes the old one too. Maybe, that's why it's sold cheaply.
      https://www.ecstuning.com/b-genuine-...e/51311884402/
      Check MVP.
      MVP provides outstanding quality parts for BMW classic vehicle owners to restore their cars and create maximum time and cost efficiency. We are here to assist you with the general or modified BMW 2002 and E30 parts fitment & quality check.
      It sells BMW E30 FRONT WINDSHIELD MOULDING SET - EARLY CHROME for $85.
      • Liffa
        • May 2025
        • 16
        Ok, thanks. So the late rubber gasket should fit the early models also πŸ‘πŸ‘
        • Liffa
          • May 2025
          • 16
          Check MVP.
          I am painting the chrome black on this car, so I will go for a black locking strip πŸ‘
          • calvino
            • Feb 2025
            • 101
            The early ones are wider. When I was sourcing used replacements for my 1987, I measured my original ones at around 36mm wide. When I sourced seals from another early model car they came in the same width
            I got mistakenly sent a late model seal, which may have been aftermarket. I have measured around it at around 24mm wide​​. This echoes what was in this thread I screenshotted awhile back.
            • Vincenze
              • Apr 2019
              • 1031
              I think the glass is the same size for early and later models.
              You should be able to use the later rubber seal plus its black lockstrip.
              URO makes them both.
              • Liffa
                • May 2025
                • 16
                Ok, thanks alot for this information. I wonder if the window frame of the chassis is different in some way or if the size of the locking strip also differs between the late and early models.
                I have now found a gasket for the early model including a black locking strip for only 113 usd shipped to me in Sweden. I will probably try that one. https://ebay.us/m/I4yXYe
