oil change
  • StereoInstaller1
    GAS
    • 22679
    I just did a change to Delo 15-40.
    Nice and quiet, I will see how it hold up as I only have 3 more changes before 300,000
    Closing SOON!
    Thanks for 10 years of fun!
    • 30secE30
      • Nov 2008
      • 100
      thanks guys i ended up putting 20w/50 in my e30 it runs great
      1990 325i BMW
      • retardotyler
        • 270
        s
        i will get my moms g35 and monkey stomp your ass she has a k&n air filter your sr20det on 20 lbs cant fuck with it
        • whiltebeitel
          • Apr 2007
          • 2098
          Originally posted by Rennsport
          No, synthetic is pointless in a motor that was designed before synthetics came out. Ur just throwing money away
          Sorry, but synthetic doesn't break down nearly as fast and holds up to greater stress/temp ranges than equivalent conventionals. Additives last longer in synthetic oils as well. "modern" engines that run synthetic only have longer change intervals and maintain closer tolerances because they can use a thinner synthetic to get the same heat protection and lubrication.
          '89 325i track sloot
          '01 530i daily
          -Enginerd
          • bimmer_E30
            • 5001
            castrol
            20w50 for the M20.
            Originally posted by e30e
            • retardotyler
              • 270
              [q
              • rThor432
                • Feb 2007
                • 3907
                I'd run 15w40 in everything I've got if it were easier to find. It's tough to find a place that consistently has 15w40 in stock here.
                Originally posted by retardotyler
                what about an m10 with 120k
                Same as the M20.
                • reelizmpro
                  • 9481
                  Yeah, I've read a lot of good things about Delo 15w-40 heavy duty oil. It's a diesel oil but it can be used in a gas engine and it's cheap! I also want to throw in Shell Rotella T synthetic 5w-40. Great oil at a great price.
                  88 M3 - LACHSSILBER/SCHWARZE
                  • delfin
                    • Nov 2007
                    • 1064
                    20w-50 is your best bet. It was pretty retarded to use synthetic.
                    I use Kendall.
                    Advanded Delphin Division
                    My e30s: 1987 325i/1994 318iT
                    • pporcaro
                      • Dec 2008
                      • 327
                      i would never use mobil one in my car.... ever
                      I wear a suit, I do coke, and I ski...:D
                      That's why I drive a BMW
                      • whiltebeitel
                        • Apr 2007
                        • 2098
                        can't switching from a conventional to synthetic or vice versa cause leaks or seal damage or something?
                        I've heard that old seals (cork, etc) can be more prone to leaking after switching to synthetic. YMMV. My car hasn't leaked any more than before (if anything, less) since I switched.
                        Rotella T is nice because of all the zinc in it. Zinc is nice on bearing surfaces, often recommended for freshly-rebuild engines (and all the e36 guys run it to keep the valve-tick down when they beat the piss out of their cars)
                        '01 530i daily
                        -Enginerd
                        • SpecM
                          • Oct 2005
                          • 4531
                          Get some Shell Rotella, its easy to find
                          I've been running it the last 4 changes in my m20 and I love it
                          1989 cirrisblau-metallic 325i
                            • 34839
                            nonsense
                            synthetics have better temperature ranges and have more base stock and less viscosity modifiers as a result. nothing wrong with synthetic in an M20.
                            if your old seals leak after changing oil, the only thing that was keeping them from leaking before was all the crud built up on them.
                            also do some time searching on ZDDP. Rotella doesn't have nearly as much zinc as people think. it's also formulated for diesel engines, entirely different application
                            • SpecM
                              • Oct 2005
                              • 4531
                              what oil do you use?
                              • TexasTerp
                                • Jan 2009
                                • 3541
                                Y'all are running some thick oil! I've been running on Pennzoil High Mileage 10w30 for the last 120k on my 280k m20. Runs nice and quiet and haven't had any issues at all. Then again the car spent 20 of it's 22 years in Houston.
                                stephenbrody.com
