I read in a thread that you cant "rev" a e30 automatic or it will ....
  • txtorquemade
    • 1758
    ... fry the clutch pack?
    What?
    I've never heard that, nor had it happen. Granted, most of my e30's have been MT's, Ive had a few autos and I'm always revving the motor. Not constantly like some ricer bitch, but when I'm working on it, etc.
    Anyone have info. REAL info, not just your goofy ass opinion, on this?
    Thanks..... mates.
    sigpic 1987 325is
  • Vtec?lol
    • Dec 2009
    • 3278
    Pretty much the shaft that connects the forward clutch pack in the transmission has a flaw. The metal bushings leak and allow the forward clutches to be pressurized while in park, neutral, and reverse. the updated bushings don't alow this, so usually if your tranny is still alive the bushing has been replaced.
    see pics,
    this is the old metal bushings that allow tranny fluid to seem through
    Updated bushings
    and this diagram shows which parts are affected
    If you google the 4hp22 you will get plenty of horror stories.
    • browntown
      • Jun 2004
      • 3524
      Note to self. excellent description
      • StereoInstaller1
        GAS
        • 22679
        ^excellent post, thanks.
        EDIT: Holy Part numbers, batman! http://www.jie.com/4hp22/4hp22.htm
        Luke
        Closing SOON!
        Thanks for 10 years of fun!
        • Vtec?lol
          • Dec 2009
          • 3278
          Luke
          Wow, thats a crazy amount of part numbers.
          all you will need to do is look up the part numbers for the new seals and the affected clutches and steel sleeves. Also a new input shaft bearing and re-assemble then you're good to go.
          • QUKBMER
            • 8178
            see pics,
            Updated bushings
            This is true and i had to do this on my first transmission in the car and will have to do it before i install the next one too.
            • StereoInstaller1
              GAS
              • 22679
              Read this too: http://www.disgruntledgoat.com/conte...ar/ZF4HP22.php
              Closing SOON!
              • SilentJon
                • Feb 2011
                • 88
                i found out about this the hard way at 3am in the middle of bumfuck. good news is reverse will still work :P
                up until then, my extent of working on an e30 was spark plugs and oil changes. i got to know the car pretty well after the trans
                • reelizmpro
                  • 9553
                  That's old news. It became a problem mostly at smog checks where they would just have the car stationary and rev up the engine for a few minutes. BMW even put out a bulletin about it I believe. Just another reason to get rid of the autotragic in these cars.
                  88 M3 - LACHSSILBER
                  89 M3 - ALPINEWEISS II
                  • Bene
                    • Feb 2011
                    • 358
                    they seem to do just fine in LR Discovery Is
                    • DaveSmed
                      • Apr 2007
                      • 1407
                      That's because its a Land Rover and it doesn't run long enough or often enough to kill the transmission.
                      -Dave
                      2003 Lincoln Towncar | 1992 BMW 325iC | 1968 Cadillac Deville
                      Need some help figuring out the ETM?
                      • b*saint
                        • 3794
                        Thank god GM make my transmission.
                        Ma che cazzo state dicendo? :|
                        • kamotors
                          • Nov 2007
                          • 7102
                          my auto tranny holds up to tons of abuse, I rev it up every now and then and spin donuts once a week. Maybe when the PO did the shift kit he also fixed the issue.
                          7speedshop.com
                          • Teaguer
                            • Sep 2004
                            • 6167
                            5-spd swap/thread.
                            • 5Toes
                              • 9836
                              I still cannot grasp
                              A. How auto transmissions work
                              B. How a guy invented the damn things
