What's the Deal with E36 vs E30 window switches?
  • TexasTerp
    • Jan 2009
    • 3541
    #46
    3. The comfort module from a late E36 plugs into a huge circuit board with roughly 9 billion connections. Good luck adapting that, or finding a way to reliably attach wires so it could be adapted to the E30.
    If your car has individual plugs that connect to that board, please let me know. I will find another and hack its guts out.
    I really do wanna see that, but damn what a hassle. I have held one in my hands. It is gonna be a bitch. That "Comfort Module" is one of 2 or 3 modules on that board...
    This is what I was wondering about, I know that the entire unit has at least 3 different modules in it (it's technically called the General Control Module iirc).
    I didn't know how/where the green input plug came from or if the General module will even operate on its own without the large black and yellow input plugs.
    stephenbrody.com
    • StereoInstaller1
      GAS
      • 22679
      #47
      I have 3 of those same boxes sitting around. If I could figure a way to even solder onto the leads safely I might do it. I really want the proper BMW setup.
      Closing SOON!
      Thanks for 10 years of fun!
      • TexasTerp
        • Jan 2009
        • 3541
        #48
        I wonder if it's possible to retrofit the system by removing the entire e30 window wiring (keep motors, guides, etc) and replace it with the small base e36 switches and integrate the control module on its own (all you would need is the correct power source). It would be a pain in the ass to rewire the entire system but it could possible work.
        Although, it sounds like you said the General Control Module is also dependent on another main circuit board, which would obviously be impossible to work with.
        stephenbrody.com
        • DaveSmed
          • Apr 2007
          • 1407
          #49
          Originally posted by ck_taft325is
          I'll be the skeptic and say it: I want a vid.
          I'll see what I can do, but I need to put my car back together somewhat before I can do that.
          Originally posted by nando
          that's fantastic! got a part #, schematic or wiring diagram? I bet it's something similar to what's built into the motor on the early E36.
          the best part is it uses a weatherpack connector, so you can wire this as if it were stock..
          Here ya go!
          EDIT: Hmm, looks like the wire colors change a bit on later models, go by terminals A B C and D instead.
          A private space for your group's photos and videos. Share, react, and relive moments together. Available on iOS, Android, and desktop. Free for new sign-ups.
          1. The GM system WILL NOT do a proper "one touch" using the BMW 1T switches: there is no way to toggle it on the 2nd click. The GM module also will not trigger from an alarm without the use of a 2nd module.
          2. Aftermarket window control modules also will not operate with the 1T window switches, you have to use the "big wire" switches, which are not as reliable as the late "small wire" E36 switches, however you do it, you will not have proper 1T switching like a late E36 has.
          1. You are correct, the GM 1T is a time based one touch.
          2. You could just build something to use them, I just drew up a nasty solution that would work (5 relays, a diode and a circuit breaker per 1t window, yuck.)
          I'm sure with more thought, myself or someone else could slim that down into a more elegant setup, though two relays minimum are required to use the low current switches, so maybe its not THAT bad...
          -Dave
          2003 Lincoln Towncar | 1992 BMW 325iC | 1968 Cadillac Deville
          Need some help figuring out the ETM?
          • StereoInstaller1
            GAS
            • 22679
            #50
            I just spent a few minutes with the '95 E36 ETM.
            Pinouts on each connector are very clear, but I don't know if they are labeled on the module. I will look later unless someone else pops up first.
            I think an E36 module would kick ass if it were controlling domelights, locks, windows and sunroof...because then, a simple "timed" output from my alarm will close the entire car.
            If I can get this down, I bet the 'vert boys would love to have that "door open vent" deal, would be way easier to close the damn doors.
            Closing SOON!
            • DaveSmed
              • Apr 2007
              • 1407
              #51
              I always wondered about that, is there any kind of feedback to the module on where the window is?
              I was screwing around with a Mustang that has it and noticed if the window was already down a bit it wouldn't do that.
              -Dave
              • StereoInstaller1
                GAS
                • 22679
                #52
                No clue, but the module needing to know where the window is could be timed, with a constant re-sync on full up. No idea how BMW did it.
                Dave, have you looked at the E36 ETM, at the body control module? Its nutz.
                Closing SOON!
                • DaveSmed
                  • Apr 2007
                  • 1407
                  #53
                  Nope, I only have a late model euro E36 ETM, is that the same deal?
                  I thought about timing too, but as age takes its toll, that could be kind of a crap shoot.
                  -Dave
                  • TexasTerp
                    • Jan 2009
                    • 3541
                    #54
                    Not labeled on my modules (2dr or 4dr) and couldn't find any clear marking on the circuit board either. Looks like just the connectors have the pinout markings from what I have.
                    btw, I'm working with 4dr #61.35-8 364 149 and I can't find where I put the 2dr module at the moment....
                    stephenbrody.com
                    • bernzpeed
                      • 3917
                      #55
                      this is getting interesting... but it sounds all Greek to me.
                      89 E30 S52
                      Transaction Feedback.
                      • mthaynes
                        • Aug 2009
                        • 79
                        #56
                        Master down for a vert?
                        Has anyone done a switch for all 4 windows to drop with a single switch in an E30?
                        • DaveSmed
                          • Apr 2007
                          • 1407
                          #57
                          That's a pretty damn good idea actually.
                          I would have to use big diodes though, there's no room for 8 relays anywhere.
                          -Dave
                          • Cong405
                            • Jul 2009
                            • 590
                            #58
                            Any new updates?
                            I remember a member on here did it to his black 325 vert. I forgot his name, but his user name started with an "O" and he lived over in south jersey. I haven't seen him post in a long time so I don't know if he still checks the forum or not.
                            • McGyver
                              • 4636
                              #59
                              I would be all over that!
                              • SoEm0
                                • 449
                                #60
                                Shop Automotive Electronic Accessories and Parts for Cars, Trucks & Vehicles at AutoLӧc! We've got you covered for all your door, window, trunk, hood, interior, exterior, lighting, and security needs. View our large selection of OEM and aftermarket products including actuators, latches, keyless entry, hinges & more!
                                What about these? I was going to order one up and see how well it works. But its a little low on the list right now.
                                CCW- when every second counts... The police are just minutes away!
