Shell V-Power
  • Jand3rson
    • 37587
    I've always used Shell V-Power 92 octane in my car, even before I had the chip. The difference between using regular and premium is there, people who claim otherwise are just wrong. No ill-will intended, but it's the truth. Higher octane gas performs better in your engine. End of story.
    • Digitalwave
      is a poseur
      • 6300
      If you have a chip, yes. But in a stock engine, with a stock ECu designed for 87 octane there is no reason to run high octane.
      RISING EDGE
      • Rob
        • 8166
        Dyno charts, please. Placebo is a bitch.
        BEERTECH
        • golde30
          • 11464
          Originally posted by Purdue89E30
          Out here in the mid-west there aren't a lot of Chevrons and they seem like a lower end type gas station, like Citgo and Clark.
          NO. Chevron is not a low end gas station. Its the only gas i will pump in any of my cars. all the other shitty gas makes my v8 cars ping like a mofo.
          IG: @Baye30
          • Bavarian3
            • 1230
            I use GT100....
            • trent
              agreed
              • trent
                double agreed
                • Brew
                  • 3060
                  Sadly, you've been misinformed. A higher octane gas is less prone to detonation (combustion in the cylinder before the spark plug sparks). Higher compression motors are more prone to detonation, and therefore require higher octane fuel. The fact of the matter is that if an engine doesn't ping with 87 octane, it won't run any better or make any more power with 91, 93, race gas, whatever.
                  '91 318is
                  • James Crivellone
                    Head Janitor
                    • 6305
                    I'll use 76, Chevron, Shell, or Texaco.
                    I won't use Arco.
                    For my 4runner I'll use Costco or Safeway as well, works fine.
                    I think its pretty stupid to drive the extra few miles to go to a certain petrol station.
                    • golde30
                      • 11464
                      didnt know you were from across the pond... :D petrol
                      IG: @Baye30
                      • James Crivellone
                        Head Janitor
                        • 6305
                        I've been reading too many european reviews/watching top gear too much :p
                        I'm not from across the pond, but I do say Bonnet/Boot/Petrol/Etc
                        • AndrewBird
                          The Mad Scientist
                          • 11898
                          In my carbureted MG, I definitely can tell the difference between 87 and 92. My engine is higher compression though and requires the higher octane, which might be why I can feel a difference.
                          On another note, higher octane fuel will make your engine run cooler.
                          • DarkWing6
                            • Apr 2004
                            • 7144
                            Hey wannabe, how those headlight wipers coming along? :D
                            • BENdashdash
                              Tom is not my friend
                              • Aug 2004
                              • 2506
                              Why is that?
                              • Rob
                                • 8166
                                still waiting to hear from Eurostar...
                                BEERTECH
