Difference E30 & E36
  • bernzpeed
    • 3917
    NOPE, just paid $600 exact.
    89 E30 S52
    Transaction Feedback.
    • bastianshaw
      • Jan 2007
      • 2210
      dont worry bernzy, we get it done :-)
      • Slick92GS-R
        • Apr 2005
        • 662
        Looks like I struck a nerve with that 'Son' thing huh? Don't get sandy sweet cheeks. I'm only trying to help.
        Sure, re-do the HG on this M42. Make sure you don't screw up the cams/timing by not using a cam lock tool. and make sure you get the install of the Profile gasket more than correct.
        also, label the 'mess under the intake manifold' so you remember where everything goes.
        pay attention to the Knock sensors so they are angled correct when you put everything back together.
        Please have the head checked to make sure its not cracked between the water jackets.
        Check water pump & radiator and Fan Clutch for proper function (wtf caused the overheat in the first place)
        Button it all up and enjoy your M42...
        --Hayden--
        '87 325 coupe- Trak Rat
        '93 318is- 4cyl's of fury
        '92 Integra GS-R--yeah, its fast..
        www.G2IC.com
        • bmwstephen
          • 2463
          so how is this engine easier than the m20 after what's said and done?
          • Conki
            • 1254
            I'm guessing fewer cylinders => lighter parts to handle, more room in engine bay for wrenching
            1992 BMW 525iT Calypso
            2011 Jeep Wrangler
            • Car Addict
              • Mar 2007
              • 1100
              mainly the more room is what is great.
              • AndrewBird
                The Mad Scientist
                • 11898
                Originally posted by dude8383
                18. Valve stem seals
                http://www.rmeuropean.com/Part-Numbe..._54299047.aspx
                Comes with all valve stem kits... I don't recall what exactly this is used for though.
                They are little plastic tubes/caps. You put then over the end of the valve so when it slides through the seal, the groove in the end of the valve doesn't damage the seal.
                • bernzpeed
                  • 3917
                  Just getting tired of being called that. Thanks for the advice though and I will definitely keep that in mind.
                  Thanks, I'm sure we will. Go Team! :-D
                  89 E30 S52
                  • TobyB
                    • 5268
                    18- not valve stem seals, the tubes you use to INSTALL the valve stem seals...
                    17- there are some injector o- rings in there, too. If you have a later M42, you actually need some o- rings from an M44, as the injectors changed size... and added an air distribution manifold..
                    16 various crush washers. You will not use all of them.
                    And if your M42 E36 is too slow, you're not winding it out hard enough...
                    ...says the man who flogs one.
                    And E36 vs E30? Generically, the E36 has the more competent rear suspension,
                    the E30 is the better- built car...
                    t
                    • bernzpeed
                      • 3917
                      thanks guys for the help.
                      89 E30 S52
                      • Kershaw
                        • 11822
                        Originally posted by bernzpeed
                        First of all, I'm not a son.
                        so you're a daughter then?
                        AWD > RWD
                        • bernzpeed
                          • 3917
                          89 E30 S52
                          • TobyB
                            • 5268
                            it's not...
                            t
                            • kingston
                              • Jun 2010
                              • 2669
                              Yes that was it. Interior was mint, no tears. Just head gasket.
                              It runs, idle is smooth.
                              He was asking $1800 and talked him down to $600. Coz I am awesome like that. LOL.
                              You ARE awesome! :D
                              Update on the gasket swap??
                              Originally posted by LJ851
                              kingston is the play by play announcer for this thread.
                              ‘Tis by the grace of God that my cars run!
                              Originally posted by unloadedak
                              #teamross
                              Siobhan's Build Thread - UPDATED!
                              • bernzpeed
                                • 3917
                                we tackled dropping the engine off the vert part out car we have. so didn't touch the e36 yet. so have to organize all the parts taken off. then we tear the other engine.
                                89 E30 S52
