Whats Wrong with Your Car?
  • hurricanevic09
    • 147
    #151
    new top.
    new bracket.
    new window trims.
    new door seals.
    ....and thats just to stop the leaks.
    new front valence.
    new entire back end. from the third brake light back, its alllll needs to be replaced.
    new front driver side fender.
    new ac compressor belt.
    valve adjustment.
    new fogs.
    new washer fluid resivour, sensor, pump.
    new antenna.
    new locking mechanism.
    new seats.
    and a wash to top it all off.
    1992 BMW 325iC <3
    • HarryPotter
      • Jan 2010
      • 3642
      #152
      bird shit on the back winda.
      John F. Kennedy
      • otto325e
        • 225
        #153
        Today I spun my car around in a snowy parking lot and smoked my rear valance on a concrete divider...fuck.
        • !kid
          • 1362
          #154
          head lights aimed to high
          sway bar bushings are bad
          sway bar endlinks no bueno
          burns alot of oil
          bad head gasket?
          bad valve seals?
          bad pistion rings?
          trans leaks a little
          hood has dents
          hood will not line up right
          clear coat is gone
          drove over fresh yellow paint now its all over inside tirewell and some on fender
          front brakelines have cracks on them
          duracrap brake pads
          center support bearing is kinda broken
          door seals are bad
          subframe bushings are in bad shape
          right rear axiel has play in it
          stock LSD is worn
          3 bald tires
          crack on front window
          front strut bearings make noise
          drive shaft out of balance
          rear swaybar bushings no good
          rear endlinks no good
          bad gas mileage
          .....but i still love driving it!!
          :borg:
          • e30lov
            • Jul 2008
            • 1597
            #155
            Power top Inop
            Obc inop
            window seals leak on heavy downpours
            car is keyed down the entire drivers side
            dash is cracked
            power steering leak
            other then that i love my car
            `92 325 vert - `90 325 coupe `99 m3 - Instagram @e30L
            • ZekeTheSneak
              • 1562
              #156
              ran over my oil cooler, dead motor.. but i get to shave my bay and add a lightweight flywheel to the new m20 :)
              • Dtmnuka
                • 124
                #157
                I have 1 problem with my car, its not an e46 m3 :) hahaha
                • Killacortes
                  • 1937
                  #158
                  heater broke!
                  r3v does not fuck around. First you get banned, then they shoot you
                  • Dozyproductions
                    • Jan 2007
                    • 4682
                    #159
                    Timing belt is near its death
                    Sunroof is broken
                    driver door hinge is fucked up
                    Horrible self done paint job. (oh it looks good at 40 feet away)
                    No bumper trim
                    Brake light is out on the passenger side for no reason.
                    No more trunk light.
                    Leaking coolant
                    But you know what? I jump in my jalopy and it makes me smile. It's something that the highschool kids cant understand when they see a dude driving a POS and looking good doing it.
                    • !kid
                      • 1362
                      #160
                      changed valve seals and Head gasket, spark plugs still have crap building up on them :(
                      :borg:
                      • E30Rookie37
                        • 308
                        #161
                        -hole in plastic on my front diving board on driver side
                        -passenger seat won't flip forward
                        -two tears in drivers seat (need some sports)
                        -6 button OBC display is half broken
                        -Inspection light comes on for no particular reason randomly while driving
                        -trunk leak(might of fixed it yesterday, only time will tell)
                        -Needs front valence
                        -Driverside fog is broken(new foglights are incoming)
                        -passenger side dome light is broken
                        -key won't lock car from passenger door lock
                        -pretty bad steering wheel vibration
                        -all rear bushings are shot
                        -Needs to be lowered
                        -needs new wheels
                        -needs some dents popped out
                        -dash is cracked and needs replacing
                        -need new blower motor
                        86' 325e
                        Quote:
                        Originally Posted by 02stu
                        They're (e30s) very sensible if you never want to get laid by anything other then a college student..on second thought
                        • Turf1600
                          • 9815
                          #162
                          My ABS doesn't work
                          My u joints are going out
                          My fan clutch seems to be dead
                          Front plastic bumper is shattered.
                          Vert top needs adjustment
                          tri-colored interior (blud cards, black fronts, gray rear)
                          • KamakaziX
                            • 2041
                            #163
                            Need tires
                            Need AC
                            Bad Power Steering Pump
                            Bad Exhaust (in the mail)
                            Comfort seats
                            Crappy headlights
                            Chrome Kidney grills
                            Rusty trunk lid
                            No wing
                            Divingboards
                            Thankfully, most of that stuff is easy to replace.
                            Originally posted by lambo
                            Fuck studying. Party hard.
                            • byza213
                              • Feb 2011
                              • 334
                              #164
                              my passenger seat worn
                              pops out of first gear now and then.
                              gear knob loose
                              starter motor need to be replaced soon.
                              1986 325e ( baur project)
                              1986 535i e28
                              1990 325i touring (sold)
                              1990 mk2 golf (sold)
                              1983 e28 525 (sold)
                              love my old girls
                              • phreshkid
                                • 4655
                                #165
                                non working central locking,
                                exhaust hangs too low,
                                I think my heater just went out too or maybe just a fuse or something.
