paint
Whats Wrong with Your Car?
I need to update my status on this thread since I have a different E30 in my possession now. The current car is a '91 325i 2-door/5-speed jobber with 201+K miles on it, and it needs the following....
steering rack
driveshaft
engine/tranny mounts
guibo
center support bushing
fix rear brakes (parking brake sticks sometimes)
tires
timing belt & tensioner
accessory belts
water pump
flush cooling system
power antenna
A/C recharge (I don't think it leaks)
clutch fan
passenger side high beam
driving lights
reverse light switch
rear suspension bushings (subframe, trailing arms)
front brake ducts
tie rod ends
flush brake fluid
There's probably some other things I'm overlooking - but that's the short list.
JonRides...
1991 325i - sold :(
2004 2WD Frontier King Cab
RIP #17 Jules BianchiComment
151,200 miles on my 1986 325es.
Problems:
- needs a valve adjustment
- needs a new CSB
- needs new trailing arm bushings
- needs new subframe bushings
- needs to have the bellhouse guibo cover removed
- passenger-side front brake pad is loose
- needs new oil pan gasket and bolt
nice to haves:
- new audio system
- E36 window switches
- Z3 antenna
- 5-lug swap
- new brakes
- hardware V1 radar detector
- 35% tint all around, 60% tint front windshield
fixes since making this post:
- fixed the biggest coolant leak. I need to tighten the coolant drain bolt on the bottom of the radiator and this should be completely gone a pulley gashed a hose, so I duct taped it to hell. Leakage fixed
- installed new hoses (that were actually too small) and t-nozzle for windshield wiper system. Need to clean the windshield fluid tank and install it back into the engine bay, and this is doneLast edited by HardTech; 10-14-2008, 07:51 PM.Comment
that door almost looks like mine lol i hit a well a fire hydrant jumped in front of me when raining and second gear and slick tires posi is no fun.k my brakes dont work right they stick when you use them crack the line loose on the master its all good they work when there is no air in them but they stick so i down shift like a real man lol.um my sun roof motor is half in the spot it goes in bolts fell out you have to hold it up and sqeeze the switch that is dangling out lol.cant use the drivers door at all nothing workk on it but the mirror,window was up ya me.um lets see what else lol,cig lighter doesnt work the 12.v outlet does.no air for summer,no odometer glove box is broke wont open,caught on fire before i owned it melted the rubber stuffz under the hood not bad and not all of it stupid people and beer dont mix.it did discolor the hood a lil in spots but its ok not to bad door is way worse lol duct tape to keep out the rain lol.front sway bar is missing the brackets to hold it up in place but is held on bye the end bushings.had to replace starter was toasted from fire to hot i guess ,crap brake lines in front under drivers side door replaced 2 feet.replaced bad injecter was running on 5 cyl for a while,and i had to push start it o ya pushing a 20,000 dollar car is great in a collage towm being a 36 year old singal man let me tell you with my duct taped door lol its awesome though when i smoke almost every car that pulles up om me thinking there car is mean.it is one sweet arse car,i got mine for 1000. it was not running at the time so i got it pretty cheep i think it says 175000 so about 185000 now since ive had it and have hit 135 mph,only mods are cold air intake nd a cheepo one at that 35 bucks blue like a k/n though.it is gray red sport seats and are worn its a awesome car i wouldent sell it for nothing well a new bike maybe or another bmw lol.Comment
The '84 eta:
-O2 Sensor (but I have a new one to install)
-Tear in Headliner (but I have a new one to install)
-CSB (but I have a new one to install)
-Tires(but I have a new ones to install)
-Getrag Rattle
-Lots
The '90 M3:
-PO's Poor Wheel/Tire choice
-I dunnoComment
shoot she runs and drives but needs to be compleatly rebuilt by Overhaulin :D-FREEDOM- is cruisin at 80, windows down and listening to the perfect song-thinking "this is it"
-The Beauty in the Tragedy-
MECHANIC SMASH!!- (you all know you do it)
Got Drop?? ;-)
Originally posted by JinormusJBut of course
E30s are know to be notoriously really really really ridiculously good lookingComment
it was not running at the time so i got it pretty cheep i think it says 175000 so about 185000 now since ive had it and have hit 135 mph,only mods are cold air intake nd a cheepo one at that 35 bucks blue like a k/n though.Comment
Yeah
Needs:
Bushings
Full Suspension
Oil Cooler..(and an oil change)
Paint Rejuvenation
New Euro Grill
Ellipsoids or Smilies
A swap (lol..definitely not but a man can wish)
Wheels (style 5 all the way)
5 lug swap (not necessary but definitely wanted)
I could go on for days but I think I'll stop here. Kinda getting depressed as I keep writing this damn list.Originally posted by csermonet47Vlad, you are handling this quite unprofessionally.
Also, you are a cock with tacky taste.
That is all.Comment
headgasket is going, throw out bearing , rear window (vert) , paint oxidation on trunk , not low and my RD's dont fit! ohh yea battery is shitty and makes me allmost late to work once a week. thats all.
at least with a 30,000 mile m20 it still gets me wet :PLast edited by e30trooper; 12-10-2010, 02:03 AM.
