Whats Wrong with Your Car?
  • payney8
    • Jun 2007
    • 899
    #136
    Stains from parking under a tree for 3 weeks, oxidation on bonnet, boot dinted, various dints along the doors and 3/4 panels, antenna only powers up on light switch, brakes are fubared, has a m20b20,
    • Ramgoat
      • Jun 2010
      • 832
      #137
      Not much. Mine needs the tps installed and a new dash (maybe front wheel bearings in the spring). I keep selling all my good dashes and the new tps is sitting in the drivers door pocket. Lately, its been too cold to do anything.
      feedback?!
      4x100 32mm Wheel Spacers $70 Shipped
      • Andy348
        • Sep 2009
        • 687
        #138
        Engine ticks, sounds like its about to blow up. Probably just valves but I'm sure the timing belt hasn't been changed in a while so it may be a rocker.
        Rear shocks blown thanks to previous owner putting on Apex lowering springs and keeping the stock shocks.
        Odometer is broken (but really, whos isnt)
        Rear left door does not unlock
        Turning signal stalk doesn't go back to neutral position
        Left turning signal blinks fast.
        Temp sensor on cluster doesn't work.
        Long start and fuel pump screeches, thinking I'm going to need a new one.
        Very rough idle when cold, so I'll be cleaning out the cold start valve/putting in new temp sensor.
        Every electric motor but the back right is broken, I've got new ones going in.
        Drivers door cannot unlock the car.
        And I think that's it.
        • Dude
          • 1119
          #139
          -Finish getting wired
          -Get full interior
          -Get Wheels and tires
          -Vinyl wrap flat black eventually.
          • kway
            • 1084
            #140
            #5 and #6 rings are shot so it burns oil, lots of oil. It also fouls those 2 spark plugs so I have to bead blast them once a week. Still runs awesome otherwise though. I'd drive it across the country tomorrow if I had a reason, I'd just stock up on oil and spark plugs first, lol.
            Inspection sticker runs out in May, I'm not planning on renewing it which makes me sad. Hoping to see the odometer turn 350,000 miles by then though.
            '84 318i - Lapisblau/Schwarz (in cryosleep)
            '06 330i - Titansilber/Schwarz
            • gearheadE30
              • Jun 2007
              • 3734
              #141
              Finish the back section of the exhaust, install the 3.73 lsd, get it on a dyno, put on the replacement ground control adjusters, weld on m3 sway bar tabs, install the gauge pod on the pillar...this stuff never ends haha
              Project M42 Turbo
              • dannyyisntt
                • 3141
                #142
                Winter car's issues:
                Needs new gas tank
                Has LOTS of rust
                Is due for a timing belt change
                Temp gauge doesn't work
                Has a slight exhaust leak behind the headers
                I'm afraid to look at the front brake lines after just changing the rears...
                Front drivers side spring needs replacement
                Passenger side dim headlight is held in place by drywall screw....
                Gotta love abusive previous owners...
                • DrMcDave
                  • 1793
                  #143
                  trailing arm bushings
                  subframe bushings
                  exhaust rattle
                  headlight adjusters
                  finish stereo - was stolen
                  Paint would be sweet but isnt' necessary.
                  • StereoInstaller1
                    GAS
                    • 22679
                    #144
                    The question was NOT "What are you doing to your car" but is "What is wrong with your car".
                    The list is too long for my feeble brain to remember.
                    Basically, everything.
                    Closing SOON!
                    Thanks for 10 years of fun!
                    • howie
                      • Jan 2010
                      • 203
                      #145
                      *squeeks* rattles & thuds. besides that.. perfect!
                      www.motoringspirit.com
                      Motoring Street Culture Couture. Street wear for enthusiasts.
                      • Roysneon
                        • 4505
                        #146
                        mis-matched springs, headlight housings busted up, rear wiper fluid lines leak into hatch, rust, rhd, dome lights don't work, no hood hinge+ hood pins thanks to PO, missing one wheel stud (has 15 studs and one bolt).
                        Originally posted by mbonanni
                        I am a pursit now.
                        • Cyrix2k
                          • 593
                          #147
                          Head gasket, turbo, clutch, and pretty much the entire engine Now awaiting a 24v swap.
                          1997 540i/6 - stock
                          1985 325 - M50NV - Getrag 250 - 2.79 LSD - MS2/e -LC-1 - 750cc injectors - Blunttech Manifold - HX35 - AEM UEGO
                          1991 318i - M50NV - Getrag 240 - 4.10 open - e36 rack - Smileys - 55w 5000k HIDs
                          • bataangpinoy
                            • Jul 2008
                            • 1636
                            #148
                            mine has no driveline in it right now.
                            My feedback:
                            http://www.r3vlimited.com/board/showthread.php?t=186328
                            http://e30tech.com/forum/showthread.php?t=74911
                            Instagram:
                            @gears_n_glory
                            @functionmotorsports
                            • E-Thirty
                              • 1331
                              #149
                              Do you feel like something is trying to penetrate your butthole?
                              • gearheadE30
                                • Jun 2007
                                • 3734
                                #150
                                Well, in light of Luke's enlightening post, here's what's wrong:
                                The idle bounces randomly due to the megasquirt ICV tuning
                                The idle is at an afr of 11.5:1 to keep it from pinging, which is not the way it should have to be
                                The diff is a small case, which likely won't withstand the power for long
                                One of the headlight brackets is either broken or missing a screw
                                The turbo bearings are going. Again.
                                timing case cover leaks oil
                                The AC system
                                The exhaust is hanging by one of the rear mounts, and is half 2.5" and half 2.25"
                                The air filter doesn't have a heat shield.
                                The electric fan shroud is 2" deeper than I want it to be
                                GC adjusters are corroded to their sleeves
                                The boost and AFR gauges are hooked up...and sitting on top of the dash.
                                clear coat is peeling
                                dents from hail
                                the handle on the sunroof is half a turn out of sync with the detent
                                driveshaft needs to be rebuilt soon
                                Needs an alignment
                                gas tank keeps pulling a vaccuum
                                driver's seat is cracked
                                passenger ebrake keeps sticking and making noise
                                passenger rear door panel has an annoying rattle that I can't fix...
                                cluster rear fog indicator isn't working anymore
                                MPG gauge doesn't work
                                I get a weird "THWWWAAAAAAAANGGGGG" noise when switching directions, i.e. forward to reverse, from the rear end
                                Such a depressing list after putting so much effort into the car haha. It never ends...
                                Project M42 Turbo
