Whats Wrong with Your Car?
  • Farbin Kaiber
    Lil' Puppet
    • 29502
    #106
    I need another one.
    • Stephen
      Шлем ишака
      • 10774
      #107
      Originally posted by Turf1600
      My brake light switch has been out for a while. I should probably get on that. Also, my AC switch won't stay in. I have a new switch - I just haven't put it in.
      That AC switch is so god damn annoying, i had that problem too. I finally fixed though, i just reached around and popped it out instead of disassembling the whole thing
      • Jand3rson
        • 37587
        #108
        Oh, and my ABS is engaging at random during low-speed stops, and I can't figure out what it is that's causing it.
        • Collin
          • 1736
          #109
          -O2 sensor
          -oil pan gasket
          -paint
          -bumpers
          -exterior trim
          -grille
          -seats
          -interior lamp
          -one broken head lamp courtesy of bambi
          Atleast it's almost all cosmetic
          The Keystone Killers
          With 73k+ post, you'd think he'd have learned a little about life.
          • e30pwr
            • Oct 2007
            • 642
            #110
            wheels bearings making loud noises
            brakes need done
            passenger side regulator is stripped
            paint is cracked nearly everywhere
            hail damage that i'm too lazy to fix
            exhaust leak that i need to seal up
            fog lights need help
            clutch likes to complain in the cold am mornings.
            • deutschman
              • May 2008
              • 5958
              #111
              -can't open or lock doer from drivers side
              -antenna is gone
              -im using 3 rota slips and one bottle cap because my tire popped and i can't afford new tires right now (fuck school and not having a job!!!))
              -my gas gauge is wacky as all get out!
              - the left side of my instrument panel needs a new light bulb
              • Pinepig
                • Sep 2007
                • 1811
                #112
                I was out today and apparently busted an exhaust hanger, I hate that buzz it makes when the pipe rests on the rear sub-frame.
                • mattdk318i
                  • Jun 2006
                  • 3953
                  #113
                  thinking about all that needs to be done is too depressing to type
                  • bignate948
                    • Apr 2006
                    • 542
                    #114
                    where to start.
                    -interior light fell out today.
                    -gas guage
                    -glove box(but whose isnt)
                    thats all ican thnk of for now
                    • nosignal
                      • Oct 2007
                      • 274
                      #115
                      - Pretty much running open header right now due to an exhaust leak, car is obnoxiously loud.
                      - Small hole in driver's floorboard and above mentioned exhaust leak means the windows have to be open no matter the weather unless I feel like suffocating. haha
                      - Windshield wipers don't work. I have a replacement linkage but a nut on the linkage currently in the car is stripped so I can't get it out.
                      - Blower motor doesn't work.
                      - AFM is dying, randomly makes the car run like shit.
                      - Loses a little oil.
                      - Has a slow brake fluid leak somewhere. Have to add more every 3 weeks or so.
                      - All sorts of minor cosmetic issues.
                      - Inspection is up this month. Won't pass because of the wipers, but I'm putting it away for the winter so it's not a big deal.
                      Despite all of that, I've put ~15k miles on it in the past 6 months and only been left stranded when the alternator ground wire broke 150 miles from home.
                      ::: Present -- '87 325e, '95 525i
                      ::: Past -- '91 318i, '95 540i/6, '85 323i Euro, '86 325es, '86 325e, '84 318i
                      • gearheadE30
                        • Jun 2007
                        • 3734
                        #116
                        I've got a massive excel spreadsheet of everything I have done since I got the car, but there's still stuff to do
                        -front lip (i lip and 740i brake ducts)
                        -small oil leak that I can't seem to find, along with a leaky oil filter housing gasket
                        -loud and misaligned exhaust and tips
                        -balky 1st and 2nd gear synchros
                        -custom dome light fell out and I havn't gotten around to making new mounts
                        -armrest is rattly
                        -Konis to go with the GCs so I can re-lower the car and not bottom out
                        -new tires
                        -paint the spoiler, valences, etc
                        -polish and wax
                        -lamin-x
                        -new swaybar links
                        -finish the 13 button OBC swap
                        luckily it seems to be a lot of small stuff. I just don't have enough time.
                        Project M42 Turbo
                        • q00pster
                          • Jun 2008
                          • 4
                          #117
                          I guess I dont have it as bad as some others...
                          1987 325is
                          Burns oil (needs a quart every 3-4 tanks)
                          Coolant is leaking somewhere
                          Coolant light is always on
                          Odo stopped working
                          Driver's side leather chair is FUBAR
                          Dash is cracked
                          Paint is faded
                          • q00pster
                            • Jun 2008
                            • 4
                            #118
                            1987 325is
                            Odo stopped working
                            Dash is cracked
                            Paint is faded
                            • Eric Giles
                              • 1068
                              #119
                              Recent '87 325iS project purchase-here is what is needed:
                              Fix broken drivers seat
                              Paint in terrible shape (but full respray and plastic bumper conversion is coming very soon)
                              Full suspension overhaul front and rear (parts on in, just waiting on me)
                              Replace carpet (Waiting on Funkmasta to figure out where it got shipped)
                              Timing belt/water pump/camshaft seal/valve cover gasket and 'doghouse' seals (Once again, I have all of it waiting for me to get off my ass)
                              That's really most of it-so far its the best running M20 I have ever owned/driven. It may not look pretty, but it's also the most fun to drive E30 of the ones I have had-yes, and that includes my two E30 M3's.
                              Eric Giles
                              '20 M2 CS
                              '04 M3
                              '11 X5 35D
                              '87 325is
                              '91 325i Sport
                              There are few things more expensive than a cheap BMW...
                              • E30Kohl
                                • Jun 2007
                                • 91
                                #120
                                Wow, mine seems to be in pretty good shape for 199,000.
                                Ok, so
                                Shift boot is ripped
                                Alignment
                                High beams work intermittently, new switch needed
                                Thats it though, besides needing Euro bumpers and an S50.
