Whats Wrong with Your Car?
  • Letoyrider
    • Mar 2004
    • 121
    #76
    Originally posted by JonG
    Originally posted by Letoyrider
    Weird noises in the back right tire (in that area)
    leaking oil from between the Head and block (ive been told)
    Needs a better batteri
    if anyone know what that noise might be please pm me (its a Weeeering noise)
    Maybe the bearing needs to be replaced?
    but the sounds doesnt increase when i accellerate....could it still be the bbearings?
    • E30godz
      • 1524
      #77
      speedo and gas gauge lights are out, and gas gauge doesnt work
      strange pop coking from right strut over some bumps
      another strange pop when turning and in reverse at slower speeds
      when i jam the gas the car kind of bucks (Maybe emptying fuelrail)
      diff or center support bearing clunking if im not smooth with the clutch work
      leaking oil out of the oil drain on the turbo (soon to the fixed)
      • Kondour
        • 243
        #78
        ya kenyon, it has an automatic and i like it. Least me car passes emissions without a glitch ;) now im giving u a hard time.
        peace,
        Derek
        • 318driver
          • 1714
          #79
          IT HAS METAL BUMPERS:
          Needs:
          brakes
          SSK
          New rear shock mounts
          to be lowered
          Valve adjustment
          a Gasket for my top so that i dont get leaked on anymore everytime it rains
          90 325is
          IE stage 3s and refeshed m20....
          • e30evolution
            West Werks
            • 1888
            #80
            RR shock blew so i have stock on it until i get a replacement
            trunk leaks a little
            radio is not held in properly
            shift selector rod rubs on drive shaft balancer (only when being pulled into 2nd gear)
            RF marker light is out (i will change the bulb someday)
            gas tank leaks if more than half full
            valves/fuel injecors make tons of noise despite proper adjustment
            steering wheel boss squeaks when being turned
            fog light button sticks sometimes
            my girlfriend thinks the seats are uncomfortable
            OBC backlight does not work
            OBC is still in metric (wont change to imperial)
            HVAC lights dont work
            http://www.westwerksauto.com
            • NC325iC
              • Mar 2004
              • 6565
              #81
              small oil leak that i cant find
              instrument cluster slightly fried(have replacement on the way)
              obc matches the instruments(hopefully will be fixed with the cluster)
              stupid clicking everything(valves and injectors)
              I HATE SQUEAKY BRAKES
              somethin loose in front right suspension
              • Beej '86 325es
                • 2639
                #82
                Needs:
                Dash
                Floor mats
                Racing seats
                exhaust
                black windshield trim
                paint job
                ...S50
                -Brandon
                '86 325es S50
                '12 VW GTI Autobahn DSG
                '03 540i M-Sport (sold)
                '08 Jeep SRT-8 (sold)
                For sale:
                S50 TMS chip for Schricks
                • bmw4life
                  • Apr 2004
                  • 152
                  #83
                  :firehop: NO AC
                  • Clay'87IS
                    • 324
                    #84
                    AC doesnt work.
                    Tranny stuck in 1st.
                    Front Vailance is destroyed.
                    Ding under right taillight is beginning to rust.
                    Taillights hold water.
                    Seats are worn.
                    I have alum. bumpers.
                    One keymark that I cannot totally remove.
                    Lots of chips (not so many now that the front vailance is gone).
                    Tach works when it wants.
                    Gas gauge is just a general idea.
                    Temp gauge is a little off.
                    Missing one centercap (thats why I took them off)
                    I could go on...
                    -Jetta GLi
                    • Kerrath
                      • Jun 2008
                      • 577
                      #85
                      Multitudes of unknown vacuum leaks
                      Manual brakes
                      Brake fluid reservoir held in with folded steel sheet
                      Brake fluid lines kinking
                      No O2 sensor
                      No cts
                      No tach, coolant gauge
                      No 5th gear
                      Radiator is loose
                      Radiator hose leaks
                      No fan
                      Sounds like a honda
                      AC compressor has holes in it
                      power steering pump is hollow
                      power lock and window doesn't work in one door
                      fenders are crumpled
                      passenger seat got mauled by the demons
                      Still more fun than a volvo 240 wagon.
                      • Stephen
                        Шлем ишака
                        • 10774
                        #86
                        Dash cracks
                        Small rust in trunk
                        ABS light
                        OBC display broken[ditching for 316 panel]
                        blown shock :/
                        Im so happy the list is so short now. It didnt used to be haha
                        • blck325is
                          • Apr 2006
                          • 1749
                          #87
                          Hmm, where to start. From the front to the back
                          Need
                          -Need to fix front valance, grill and light
                          -Replace both fenders
                          -Fix Steering rack
                          -Major tuneup=Hose, tbelt, waterpump, valve clearances, check oilpan (this is a long list..)
                          -Fix other non-tuneup related leaks
                          -Replace suspension (blown shocks and crap springs)
                          -Replace brakes
                          -Heater core
                          -Replace odometer and misc fuses
                          -Replace front seats (broken frames)
                          -Replace sunroof, crank and seals (or paint)
                          -Replace drivers side door and rear drivers side door
                          -Get bodywork done on rear left quarter panel
                          -Fix electrical gremlins in radio, speakers, interior lights
                          -Get new exhaust hangers
                          -PAINT after body work, door replacement and all fender replacements
                          Oh and it is a daily that I love regardless of all the grief it has put me through.
                          I need a new car or a warehouse of e30 parts and a team of mechanics..dammit if only I was vlad.
                          Originally posted by csermonet47
                          Vlad, you are handling this quite unprofessionally.
                          Also, you are a cock with tacky taste.
                          That is all.
                          • dashboardmonkey
                            FUCK YOUR WAFFLES
                            • Jun 2008
                            • 6158
                            #88
                            Motor trans needs put in (tomorrow)
                            Needs dash and everything to do with it
                            Need ecu
                            Need diff
                            Need driver seat
                            Need blinker/cruise/wiper switches
                            Need clutch master cyl
                            Need radiator
                            Needs to get lowered
                            Needs Paint/bodywork
                            Need stereo
                            That's all I can think of now
                            aaaaaaaahhhhhhhh................FUCK!!
                            Time to go to bed
                            Andy
                            EDIT: just remembered more
                            Need to install taurus skirts
                            Volvo lip
                            -Andy
                            • kronus
                              • Apr 2008
                              • 13032
                              #89
                              - bits of rust in places
                              - worn CABs, balljoints
                              - heater core leaks and fogs up interior
                              - system is convinced that the brake light circuit and the license plate light circuit is faulty
                              - not enough window washer fluid
                              - peeling liner on header panel
                              - busted seat shocks, seats fall back when adjusted
                              - weird noise at 1500 RPM, probably a heatshield somewhere
                              - another weird noise when cornering... may be rubbing tires
                              - left high beam fuse burns out often, have no idea why
                              - jangly exhaust due to shitty welds
                              - turn signal goes to other side when disengaging from one
                              - front wheels need refurb
                              - it's an eta
                              EDIT holy thread bump, Kerrath
                              cars beep boop
                              • Stephen
                                Шлем ишака
                                • 10774
                                #90
                                :ohsnap:
