Whats Wrong with Your Car?
  • SamE30e
    • Sep 2007
    • 4319
    #91
    What isn't..
    1985 325e 2.8 Turbo VEMS
    • z31maniac
      • 17566
      #92
      Holy thread bump batman.
      Not really anything wrong, just lots of upgrades I'd like to make.
      www.gutenparts.com
      • T Verdier
        • Aug 2007
        • 2636
        #93
        -torque, or lack there of
        -revs, or lack there of
        -lackluster throttle response
        -sewing machine sound
        -stock suspension
        • archemedes
          • 125
          #94
          head gasket
          clutch master
          si board batteries
          then cosmetic
          • JAM
            • Feb 2007
            • 524
            #95
            i think a better question would be what is good with the car?
            in my case, i need-
            a new fender
            body work on the rear quarter
            lots of wiring work done
            valve adjustment
            tires
            an alignment
            a tie rod on the pass side
            lots more that i dont feel like listing
            Originally posted by Mr Watsonsilver
            driving boards?
            • Turf1600
              • 9815
              #96
              My brake light switch has been out for a while. I should probably get on that. Also, my AC switch won't stay in. I have a new switch - I just haven't put it in.
              • morningsmiler
                • Jun 2008
                • 230
                #97
                blower motor making noise
                valves need adjusting
                exhaust nearing the end of its life
                sloppy shifter
                rear wheel bearing
                I still drive it everyday, though!
                • jflip2002
                  • Sep 2006
                  • 4377
                  #98
                  -Plastic bumpers discolored. way darker than the rest of the car
                  - rear valance needs replacing
                  - Knee bolster needs replacing
                  - Cracked right foglight
                  - Bottle caps...
                  Originally posted by blunt
                  • speedhop
                    • 1509
                    #99
                    Oh this is a fun thread...from 2004
                    -Hood dent
                    -Door dings
                    -Quarter panel dings
                    -Dirty as shit
                    -Crazy gas gauge
                    -No A/C
                    -No Power steering
                    -Needs RTABs
                    That's about it...:) I still love my m30 and it's torque.
                    www.ryanwhopkins.com
                    • Jand3rson
                      • 37587
                      #100
                      It's an eta.
                        • 34844
                        #101
                        my brakes suck - still using the same pads I killed at a track day earlier this summer. master cylinder is mushy, front right caliper is stuck and dragging, pads are glazed over and my rotors are pitted. However I just spent $300 to remedy that problem. :)
                        • bimmer_E30
                          • 5001
                          #102
                          Needs brakes.
                          o2 senser.
                          blown shocks.
                          needs spark plugs
                          plug wires
                          d-cab
                          stock 4X4 suspensions
                          Ac recharge
                          fog lights
                          new fender + paint
                          timing belt and water pump
                          oh and its an ETA
                          Originally posted by e30e
                          • SpecM
                            • Oct 2005
                            • 4531
                            #103
                            -LF wheel bearing grinds/rattles
                            -No AC
                            -P/S pump is dying
                            -driveshaft has clicky joints
                            -All four shocks are shot
                            -No parking brake on the LR
                            -No radio
                            -dash cracks
                            -Ball joints and/or CABs
                            -Steering rack leaks
                            -needs new ignition wires
                            -stock susp/wheels/slushbox
                            -RF tire is rubbed down to the wires!
                            1989 cirrisblau-metallic 325i
                            • StereoInstaller1
                              GAS
                              • 22679
                              #104
                              List of shit wrong/things I don't like about my car?
                              Fuuuuuuuuuuuck, I can't type all that.
                              Closing SOON!
                              Thanks for 10 years of fun!
                              • Jean
                                • 18228
                                #105
                                Ok here we go.
                                - driver side door lock mechanism is sticking... (maybe needs to be aligned?)
                                - need new front/rear pads (20k miles on street pads)
                                - idle shoots to 2k-2.5k on start ups (hopefully new gaskets/o-rings for injectors will fix this)
                                -need to install heater core/valve/lines.
                                -need to install inner door water protection sheets
                                -need to plug all the holes in the rear valance/trunk area
