Summer plans. Thoughts?
  • jaywood
    • Jul 2010
    • 4528
    Here's what I have planned for the summer:
    New clutch
    Oring block (probably)
    Head gasket change
    Megasquirt pnp
    Timing belt
    More boost
    For all of you guys who have done that ^ I know you can keep the engine/tranny in the car, but would it be easier to pull the engine/tranny and replace things on an engine stand? I already have a cherry picker and an engine stand. Just looking for the easiest way to do all that. If I pull it I can clean up the block and what not, that would be a plus. It could use a good cleaning.
    Keep engine and tranny in car, or pull both?
    Thanks guys ;)
  • 10Toes
    Me Father Was A Tree
    • Jan 2008
    • 61222
    I would pull it just to clean everything and it would also make the work easier.
    • andrewm
      • 456
      Pull it. It isnt a whole lot more on top of the head coming off, and you wont be crouched over.
      1987 Delphin 325e Sedan - Natalie
      1990 325i 24v
      1997 Chevrolet K1500 Crew Cab 4x4 - The Centurion
      • F34R
        sLaughter
        • 12376
        Leave it in, the hours spent removing and installing could be put towards all the work you have listed.
        Instagram: @BWeissLeather
        Current cars:
        ~ '87 325 M30B35 swap
        ~ '87 535
        ~ 01 540 Msport 6spd
        ~ '06 X5 4.8is
        • JasonC
          Site Manager
          • 14451
          Pulling it would be a plus. The extra work will pay off if you're looking to clean everything and look good once its all back in the car.
          1992 BMW 325iC
          1978 Chevrolet Monte Carlo
          • ZekeTheSneak
            • 1562
            Pull it, much easier to get to everything on the block and route coolant and wiring. I would invest in the m3 wire cover and bay shave to be extra ballin :)
              I'd pull the engine. Heck I pull the engine & transmission just to change a clutch. If you know what you are doing and have the right stuff and engine/trans pull or install can be done in a bit under three hours.
              • Dj Buttchug
                • Jun 2010
                • 7672
                yep. pull the engine
                Turbo M42 Build Thread :Here
                Ig:ryno_pzk
                I like the tuna here.
                Originally posted by lambo
                • Cronopoulos
                  • Jul 2011
                  • 2187
                  Pulll outtttttttttt
                  Project log -- DIRTY 30
                  2.7i * Megasquirt tuned * E85 powered
                  • Swanny
                    • Mar 2012
                    • 2834
                    just spit on her back and tell you pulled out
                    but in the case of the engine...why the hell not yank it if you have the means to
                    Swanny!
                    SUCKERS.
                    • jaywood
                      • Jul 2010
                      • 4528
                      Thank you guys.
                      Looks like I'll be pulling it!
                      • jeffnhiscars
                        • Jun 2011
                        • 6010
                        Takes me 3 hours just to remove a heat shield...but I do a really good job of it
                        Alice the Time Capsule
