10k in Mods
  • george graves
    • 19997
    I'd buy a vlad paint job.
    Originally posted by Matt-B
    • Jalves619
      • 596
      I'm at about 4k w/ an S50 and full Mcoupe suspension, but I did get pretty lucky on most of the parts. Another 6k and I'd have a fully built motor w/ a turbo, but then you are quickly moving away from a reliable daily driver.
      • dannyyisntt
        • 3141
        Strippers and cocaine. That is all.
        • OniKyan
          • Sep 2011
          • 671
          Assuming the car is in good condition and needs no maintenance, for me it would be something along these lines.
          Suspension/Wheels
          BC Gold - 8KG/MM front, 10KG/MM rear - $1,200
          Urethane bushes everywhere - $300
          IE 22/19 Sway bars - $440
          Custom built strut tower braces - $200
          15x8 et15 meshies + 205/50/15 - $2,000
          = $4,140
          Engine/Drivetrain
          MM 2.9 Stroker - $1,900
          Miller MAF + W.A.R = $700
          4.10 LSD - $500
          Aluminium Flywheel - $500
          Clutch - $300
          Z3 based short shifter - $150
          eBay headers - $200
          Magnaflow 14815 - $200
          = $4,450
          Interior
          Recaro SRD/Bride Zeta etc - ~$1,000
          Momo Prototipo - $200
          ZHP Shift Knob - $60
          = $1,260
          Total = $9,850
          All prices from memory, or rough estimates/guides. Also, if you can't work on cars yourself, then you may as well go and add another $5,000 on top.
          M20B23 Euro 323i - The Legend Of Ron Burgundrot
          • 33xander33
            • 46
            Hey thanks guys, if I had my choice I'd definitely go back on time and get a coupe if I could but non american trucks are rare in wyoming as it is lol. I might go the route of making it run perfect then build up the suspension if I have any left I'll do the paint too.
            • fronton
              • Oct 2009
              • 1262
              In the oil field, you need a truck, not an E30. If your dad is offering to contribute 7-10k for you to get a vehicle that makes sense for your situation, and you take advantage of that by dumping in it a vehicle that does not make sense, you will regret your decision and your father will resent his kindness.
              A. Get a $6,000 toyota T100 and tell your dad to keep the change
              B. make and save money working in the oil field without worrying about cracking another m20 oil pan
              C. when you have disposable income from the oil field, improve your e30.
              • TimKninja
                • 2131
                Every suspension part on the car.
                And make sure the engine is completley up to snuff. All maintence done.
                And maybe a respray?
                1985 325e M50TU(Sold)
                1991 318is Slicktop (Sold)
                1990 325is Brilliantrot S50/5 Lug Swapped.
                1992 525i Manual shitbox Winter Beater
                • flyboyx
                  • 8371
                  i agree with fronton. i wouldn't get a wimp truck though i suppose it depends on your purpose. i think that you could buy a 99 or 2000 f250 diesel for the 6k that was mentioned in that thread. i get 18 mpg with mine as a dd. it has enough size and power that you can do some serious work with it. also nobody laughs at you when you pull up to the job site.
                  as far as fixing your car, i would also completely redo the suspension, m50 or m52 engine swap. perhaps 5 lug. assuming the paint is good that is.
                  Gigitty Gigitty!!!!
                  • evandael
                    • Oct 2009
                    • 2881
                    OP, get a truck. like a 10 year old silverado or tundra or something.
                    • Kershaw
                      • 11822
                      how about down payment on a house?
                      AWD > RWD
                      • mikeedler
                        • 6707
                        if the reg. maint. is all up to par.
                        suspension- wheels- paint.
                        • Robotin
                          • Jun 2011
                          • 4471
                          Euro S38B38
                          1989 325i SETA stroker [delphin] R3V'd 8/31/2011
                          1989 325ix [zinnoberrot] $OLD
                          1970 2002 [Nevada]
                          Originally posted by Herr Faust Schinken
                          guy must have slid into something that doesn't look like a car vs car hit
                          Originally posted by ak-
                          Must of slid into Rob
                          • mrsleeve
                            • Mar 2005
                            • 16386
                            I would be buying something 4wd and reliable to make sure I get my ass to work. I have worked around Wamsutter and it fucking snows there. Also bosses dont take kindly to "I cant get to work because my "CAR" wont go in the snow". Once you have the DD taken care of then you can Dump the 10k into your fun car, its time to be responsible. I would be getting a 6-8 year old 1/2 ton at BARE minimum, but oil field and pipeline ROW roads are not too kind to 1/2 tons, 3/4 ton would be better. Also a older 3/4 GMT400 Suburban would be acceptable as well. Can be had Cheap and Cheap to fix and Maintain, as well as easy to work on.
                            I work in the oil fields too
                            Originally posted by Fusion
                            William Pitt-
                            • dannyyisntt
                              • 3141
                              Buy this and do an engine swap
                              Or be an adult and buy a vehicle suitable for your new work environment
                              • Stanley Rockafella
                                • Aug 2011
                                • 4060
                                Originally posted by Raxe
                                $10k in modifications doesn't go too far if you're playing with the big boys, but last time I bought one for 10ish grand it had an S38. You'll likely get more for your money buying than building.
                                Best response yet!
                                IMHO, I'd never dump that much $ into an e30..unless it was an m3. You'll never get your $ back, esp. if the car were totalled in an accident (or hit and run, etc.)
