What's the problem with "granny shifting?"
  • willworkfore30s
    • Aug 2011
    • 1090
    #46
    I'm getting koni adjustables....more traction for the hole-shot
    • dashboardmonkey
      FUCK YOUR WAFFLES
      • Jun 2008
      • 6158
      #47
      Originally posted by dothadance
      monica!!!
      i lol'd
      -Andy
      • bowtie2bimmer
        • 830
        #48
        And I heard you save like 2 lbs!
        1987 BMW 325ic - Emma
        • ELVA164
          • 4861
          #49
          Oh no...I have koni adjustables... :(
          • willworkfore30s
            • Aug 2011
            • 1090
            #50
            Oh no, those are for honda civics with spoon engines. Those things desame all at race wars!
            And you don't have koni adjustables...you never had em'... you never had your car!
            • ELVA164
              • 4861
              #51
              Agh, I knew it was a lie! I need to stop drinking so much absinthe with LSD chasers...
              • Roysneon
                • 4505
                #52
                'Spoon engines' always got me haha
                Originally posted by mbonanni
                I am a pursit now.
                  • 34844
                  #53
                  Originally posted by smooth
                  no, it reduces wear on your syncros.
                  now whether you care or not depends on your wallet or how long you intend to keep your car or current driveline
                  in a weaker transmission, like my girlfriend's geo metro, after enough abuse it's simply not possible to downshift into 2nd or first *without* rev-matching.
                  in a stronger transmission like the getrag 260 you may not notice it after a hundred or two hundred thousand miles...but whoever changes your oil (assuming you even do change your oil) will see the molybdenum (which is a whole lot more expensive than typical brass syncros).
                  you're right to note that not double (de)clutching risks premature wear of the pressure plate...but would you rather wear out a consumable or the internals of your extremely expensive and officially non-serviceable transmission?
                  your syncros are there to smoothly *up* shift. using them to down shift is senseless wear
                  G260 syncrhos are usually brass.
                  also, they're there for both. and it's called rev matching, which also reduces wear on synchros and everything else. yes, double clutching is stupid for the most part. it might be an interesting skill to learn, but seeing how a G260 will typically outlive the car that it comes in, it's completely pointless to do it in reality.
                  this is one of the dumbest threads in recent memory. I actually thought it was a thread bump from 10 years ago.
                  • ELVA164
                    • 4861
                    #54
                    Well, lesson learned on a couple levels.
                    • lambo
                      Captain Scene Points
                      • 10953
                      #55
                      Just polish up on your Fast and Furious references and everything will be swell haha
                      • ELVA164
                        • 4861
                        #56
                        Agh, I see now that it will help me fit in here, but those are such terrible movies....I would like to see the 20-speed manual gearboxes they used, though.
                        • lambo
                          • 10953
                          #57
                          They're so terrible they're good
                          • smooth
                            • Apr 2005
                            • 1940
                            #58
                            G265 uses brass. G260 uses molybdenum.
                            I don't know why you would think that a specific model of transmission would "usually" be something as if some 260's are moly but most are brass...it would be all or none. Maybe you meant to write that syncros in general are usually brass? That is true.
                            If it was brass that would make the problem even worse since brass is softer and then they wouldn't last as long as you have observed.
                            Das ist nicht nur nicht richtig, es ist nicht einmal falsch!
                              • 34844
                              #59
                              Some come with atf stickers, some with mt fluid. This isnt new.
                              • GillesBigCowboy
                                • 507
                                #60
                                Originally posted by kway
                                Nothing new here, but I fucking love it.
                                I can't get enough if that
                                87 4dr specE30: Bitsy (lurking above), 89 4dr 325i blau, 91 318is brillrot, 90 325ivertbronzit
