whats this part called?
  • mlishn
    • Apr 2013
    • 13
    does anyone know what this part is called?
    the black part, not the fuse box cover.
    should it contain fuses/ relay?
    thanks in advance.
  • reelizmpro
    • 9551
    Auxiliary fuse box cover.
    88 M3 - LACHSSILBER
    89 M3 - ALPINEWEISS II
    • dashboardmonkey
      FUCK YOUR WAFFLES
      • Jun 2008
      • 6158
      flux capacitor
      -Andy
      • mlishn
        • Apr 2013
        • 13
        does it contain a relay or its just supposed to be a plastic cover?
        • deutschman
          • May 2008
          • 5958
          The black thing on the side or the blue fuse box cover?
          • mlishn
            • Apr 2013
            • 13
            • chance
              • Feb 2012
              • 671
              I have no idea. Mine has two wires that go into it, but the weird part is that they each go to different slots. So if you look in the top with a light, you can see that each slot only has one connector in it.
              I guess its to hold fuses, or is a spot for fuses for options that I dont have.
              1991 335is in progress
              • mlishn
                • Apr 2013
                • 13
                I'm trying to figure out if its supposed to be filled or empty is ok too.
                Mine is currently empty. Not sure whats supposed to be there
                • Click
                  • 637
                  I think it is there to hold fuses if you install additional stuff.
                  ส็็็็็็็็็็็็็็็็็็็็็็็็็
                  I need you to exfoliate my ballsack
                  Build Thread?
                  • Dj Buttchug
                    • Jun 2010
                    • 7680
                    it comes from the factory empty. Its a constant 12v and a ground. Good place to run an E fan or other accessories.
                    Turbo M42 Build Thread :Here
                    Ig:ryno_pzk
                    I like the tuna here.
                    Originally posted by lambo
                    • Poorboyz
                      • May 2012
                      • 2117
                      I always wondered what that was for. I'm planning on doing a Mark VIII fan that replaces the aux fan in front and was thinking about using this since I noticed it didn't have anything hooked to it.
                      Rebuilding since 07/06/2016
                      Poorboyz Parts For Sale - Updated 01/20/17 - Will be updated soon - Have many parts to post
                      Poorboyz Feedback Thread
                      • shameson
                        • Jun 2012
                        • 1507
                        Originally posted by dashboardmonkey
                        flux capacitor
                        I second this
                        '84 Alpine 325e (Gone)
                        '91 Alpine 318i (Gone) Click Here
                        '92 Alpine 325i Cabrio (Gone) Click Here
                        '91 Alpine 318is
                        • McGyver
                          • 4636
                          actually i'm pretty sure its a constant 12V and a switched 12V. i used the switched 12V when i put in rear fogs so i could run a relay and an indicator light in the cluster.
