Why 5-lug over 4-lug......?
  • Jand3rson
    • 37587
    #31
    Originally posted by Raxe
    I looked at the cost of doing a proper 5-lug conversion and realized you can get practically any baller 4x100 wheel setup you want with that budget. Doesn't really make sense unless you're getting a hell of a deal on the parts.
    Pretty much.
    • Roysneon
      • 4505
      #32
      Originally posted by IronFreak
      I have a backup plan if it doesn't fit the fender. I just wanted to aim at a wheel that whould give me proper traction and then go from there.
      Originally posted by Ray Smoodiver
      Because that's how it rolled out of the factory (narrowbody factory 5-lug, oooo yeaaaa).
      Wat
      Originally posted by mbonanni
      I am a pursit now.
      • nrubenstein
        • 3148
        #33
        Well, E30 M3 5-lug gives you much better front suspension geometry options. But most 5-lug swaps are mediocre.
        2002 BMW M3 Alpinweiß/Black
        1999 323i GTS2 Alpinweiß
        1995 M3 Dakargelb/Black
        - S50B32/S6S420G/3.91
        1990 325is Brilliantrot/Tan
        1989 M3 Alpinweiß/Black
        • Northern
          I like cupcakes & sh!tboxes
          • 5247
          #34
          bump steer correction as well, if you're into that kind of thing.
          Originally posted by priapism
          Originally posted by shameson
          • IronFreak
            • Dec 2012
            • 3702
            #35
            Originally posted by todd black 88
            i may have the parts to make a set of 3 piece act wheels, that would fit your needs, perfectly. I have a line on a set from a vette that are 17x9.5" et 56 now, with what looks to be either 1" or .5" lips on them now. I have a set of 4 2" lips left over from my build of my act wheels, so they would either end up 17x10.5" or 17x11" et in the mid 30s i think. Or stay staggered. That work for you?
            They look like this, although they are missing the caps.
            oh my lawd..............
            Instagram @rebellionforge
            • IronFreak
              • Dec 2012
              • 3702
              #36
              So its clear, this isn't a question of whether I should go 5-lug, I already am. More of the overall benefits.
              My current setup is:
              e36m3 struts
              eyeball CABs
              Koni cut-n-gut inserts in front
              Koni Porsche 911 rear shocks
              Bimmerworld billet rear mounts
              GC coilovers
              e28 camber plates
              z3 hubs
              Rotors and calipers that match accordingly.
              I currently have about $2700 in my setup
              • alB5
                • 785
                #37
                when you run out of stuff to do that isn't related to wheels
                1991 318is -> 2004 R32 -> 2002 Jetta TDI -> 2014 FiST
                No E30 Club
                • reelizmpro
                  • 9545
                  #38
                  Years ago you pretty much had to if you wanted much better wheels and brakes + bragging rights. Now there are many options like adapters, fillndrill, E36 suspension from the Junkyard, sleeve/hub kits. For most people who just drive the car on the street and only want to run 5 lug wheels, it's hard to beat adapters and E36 5 lug swap. There are more affordable 4lug BBK kits out there as well. 5 lug swap is like the icing on the cake so to speak. I thought about doing a 5 lug on the M tech vert but couldn't justify it so I purchased 42DD adapters...no complaints!
                  88 M3 - LACHSSILBER
                  89 M3 - ALPINEWEISS II
                  • Ray Smoodiver
                    • Jun 2004
                    • 8809
                    #39
                    Originally posted by Roysneon
                    Wat
                    South African factory special, 1/500 built ;D
                    • enigmaticdream
                      • Jan 2010
                      • 572
                      #40
                      Unless you happen upon a 5 lug swap for a good price it isn't worth it. The stopping power isn't that improved and most of the wheel selection isn't all that much better. Sure a bigger front wheel bearing would be nice, but how often do wheel bearings go on e30s? It isn't exactly a common thing.
                      My reasons for doing a 5 lug swap on my 325 was to consolidate wheels. That way I only needed to find wheels of one bolt pattern and one offset range. Originally I was going to do an e36 M3 front with e30 M3 rear, but I got lucky and found e30 m3 front setup for a good price. Looking back I'm happy I didn't go with the e36 setup because I can easily swap wheels between the two e30s without worrying too much.
                      1986 911 Supercharged Frakenstrat/Stripped
                      1987 325is Delphin/Black (Olga)
                      1988 M3 Zinno/Natur (Elsa)
                      Manual or STFU
                      E30 Chapter of BMW Car Club of America
                      E30 Oktoberfest 2017
                      • Roysneon
                        • 4505
                        #41
                        I saw you mention something about the factory 5 lug before and thought it was maybe a 320is but I think they came 4 lug anyway. That's a cool fucking car you have there! Is it LHD?
                        I am a pursit now.
                        • IronFreak
                          • Dec 2012
                          • 3702
                          #42
                          Ray Smoodiver -
                          your car is beautiful dude.
                          • Shangsta
                            • 1485
                            #43
                            All South African cars are rhd
                            :shock:
                            • mrmckie
                              • 728
                              #44
                              agreed...and still have money left over for a big brake kit for your stopping power. you already have 2700 into it with no wheels yet...
                              "I came into this world, not chiefly to make this a good place to live in, but to live in it, be it good or bad" -Henry Thoreau-
                              1991 318is - the cruiser
                              1989 325i - the rats nest
                              • IronFreak
                                • Dec 2012
                                • 3702
                                #45
                                Yup.........
                                e36m3 struts (bought all the M3 stuff for $850......the so called complete kit was sent with wrong control arms, had to source two actual m3 arms)
                                eyeball CABs ($180)
                                Koni cut-n-gut inserts in front ($270)
                                Koni Porsche 911 rear shocks ($350)
                                Bimmerworld billet rear mounts ($100)
                                GC coilovers ($460)
                                e28 camber plates ($300)
                                z3 hubs (came with m3 parts)
                                Rotors and calipers that match accordingly. ($300)
