Most overlooked e30 repair
  • volvolover
    • Jan 2014
    • 89
    #31
    Originally posted by ArtClassShank
    Driveshaft. I've seen people say "eh, all E30's clunk a bit", and others talking about how much of a sweet fix it is.
    Maybe I'm confusing "overlooked" with "time consuming and expensive".
    Originally posted by arch4ngel
    Subframe bushings.
    yes and yes!
    Originally posted by 2man
    Fuel filter & lines
    currently doing that on mine before tending to this
    Originally posted by TurboJake
    Early stage rust.
    • James Crivellone
      Head Janitor
      • 6305
      #32
      I'm going to take this one step further and say one overlooked e30 repair is the idiot in the drivers seat who..cannot..drive.
      So many cars could have been saved if the owner took some of that stance/bc/whatever money and spent it on a drivers education day.
      • 15Michaeljoseph
        • Aug 2013
        • 1693
        #33
        Originally posted by mrcheezle19
        Cabin Filter
        +1
        Blinker fluid either too low or hasn't been flushed in 100k+
        --sent from my igloo via carrier penguin
        (OO=[][]=OO) For Life
        • HennaE30
          • Apr 2014
          • 1965
          #34
          Originally posted by F34R
          Control arms or the transmission shifter bushings and that gear selector bushing.
          Lol exactly what I have to do with my car. How can people drive with shot shifter bushings
          Originally posted by flyboyx
          how about if i yank the anal beads out of your ass like i'm trying to pull start a chain saw?
          Originally posted by Northern
          beer is my new liver cleanse.
          Henna - '84 Hennarot 325e
          Lola - '89 Schwarz 325is - being saved
          Christine - '88 Schwarz 325is - Spec E30 Racecar
          '01 White F150 Lariat 4x4 Supercrew - Daily
          Dad's '05 Interlagosblau M3
          • roguetoaster
            Biggus Tippus
            • 7830
            #35
            Pedal assembly bushings and interior creaks/rattles.
            • ThatOneEuroE30
              • Dec 2013
              • 8626
              #36
              Any and all rust.
              1991 318i 4dr slick top
              Mtech 2 turbo restoration
              • 15Michaeljoseph
                • Aug 2013
                • 1693
                #37
                my rattles are caused by the stock cassette deck cleaning kit in the glovebox, and loose screws on the headlight switch
                • Julien
                  • 7471
                  #38
                  working antenna, a/c, a/c switch that still lights up properly, headlight switch bulb
                  Build Threads:
                  • Shock(/\)ave
                    • 350
                    #39
                    We should either add D.I.Y. thread links to these submissions, or start a new thread with them included.
                    I'm pretty sure I'll need to do a lot of this stuff soon enough, and I don't know my way around E30s well enough to figure it out myself yet.
                    • jeffnhiscars
                      • Jun 2011
                      • 6011
                      #40
                      Originally posted by NitroRustlerDriver
                      Ok, I'll bite. What is a wiper damper?
                      Edit: Looked it up on real OEM. Looks like a rubber bushing for the arm pivots?
                      They go around the arm drive shaft and lock in to the cowl sheet metal
                      Originally posted by Ocell
                      Oh hey, I think I need those!
                      Originally posted by 88BlackS-ETA
                      Agreed. Didn't know about them until I read it in a post...Very easy to replace. Just grab your wiper arm and see if it has excess play in the base.
                      You guys made my point... Thanks !! :D
                      FYI theres a write up on these in my build thread and Im actually doing a tech session on them at the Blue Ridge BMWCC BBQ. You wont want to miss it ;D
                      Alice the Time Capsule
                      • 15Michaeljoseph
                        • Aug 2013
                        • 1693
                        #41
                        broken 'oh shit' roof handles, and a powder blue rear deck
                        • yaz3
                          • Apr 2014
                          • 25
                          #42
                          I second that
                          Yaz from the 'burbs of Chicago
                          '90 E30 325iC, nothing done; Yet
                          • Eddie Haskell
                            • 102
                            #43
                            Drivers side door break. Steering Rack, Seat shocks, a/C system, Fuel lines, Oil pan leaks, bad idle, O2 sensor, engine vacume leaks,ck panel/ cluster shorts and odometer gears. Trunk and Rocker rust along with window/sunroof problems. Lastly crap paint along with dry rot ripped seat covering.
                            • GillesBigCowboy
                              • 507
                              #44
                              Racetrack time. The soul of every e30 chassis NEEDS fast closed circuit hours (verts, and maybe wagons, are excepted for a decade or two).
                              87 4dr specE30: Bitsy (lurking above), 89 4dr 325i blau, 91 318is brillrot, 90 325ivertbronzit
                              • Julien
                                • 7471
                                #45
                                you mean fix the nut behind the wheel before anything else?
                                Build Threads:
