Most overlooked e30 repair
  • 15Michaeljoseph
    • Aug 2013
    • 1693
    #61
    Hahaha my 87 doesn't have a trunk shock ftw!
    --sent from my igloo via carrier penguin
    (OO=[][]=OO) For Life
    • Ether-D
      • Sep 2011
      • 2838
      #62
      I believe it's just cabrios that have the trunk shocks.
      Originally posted by Andy.B
      I was born on 3/25…
        • 37834
        #63
        Indeed.
        Grover Beach, California
        BimmerHeads.com
        • JinormusJ
          • 6887
          #64
          On the hardbody chassies, the trunks are held open by love and magic.
          No shocks needed
          • jdt10768
            • Feb 2013
            • 484
            #65
            Originally posted by Julien
            I nominate the hood shock or that stupid little "T" for the washer fluid inside the hood.
            any more?
            quick question about the washer fluid T connector:
            when replacing it, do you replace or somehow reuse those funky little metal hose clamps?
            I assume my T connector is clogged/fubar-ed cause I'm not getting washer fluid at the driver's side nozzle/sprayer, but it does spray @ the pass side
            • dnguyen1963
              • Nov 2011
              • 2651
              #66
              Aluminum elbows connecting to the throttle body as a source of vacuum leaks.
              • Chinampa
                • Jul 2013
                • 247
                #67
                a little off topic but how do you go about fixing that? Mine are always floppy
                - 90 325is
                • e30vert
                  • Jan 2005
                  • 1789
                  #68
                  Those elbows are press fit and they have splines cut into them. Over time with expansion and contraction the splines stop sealing correctly. I removed mine by wiggling back and forth to further diminish the splines (wear them down). Then I mixed some 2 part JB weld and coated the outside of the spline area. Pushed em back in and immediately adjust them to the proper angle. You get one chance at this as you do not want them to "set" in the wrong position.
                  Let dry over night ad they will be rock hard. Wipe off excess JB weld spooge if some comes out and do not put on excessive amounts that could find thier way into the tube like opening of the elbows inners.
                  • dnguyen1963
                    • Nov 2011
                    • 2651
                    #69
                    I pushed mine in tight then JB weld the outside. You can roll the JB into a thick noodle then wrap it around the elbow connections...press the JB flat and you are done.
                    • clint-o-matic
                      • 36
                      #70
                      The interior hood release handle. Dam things just snap off. This will be my third time replacing within 5 years.
                      • jaywood
                        • Jul 2010
                        • 4528
                        #71
                        Did one on my e30 too. Kind of a bitch to route that cable thru the grommet.
                        • DER E30
                          • Sep 2013
                          • 2349
                          #72
                          Stuck shut glovebox mod... Makes it funny to get pulled over, "yeah my glovebox is holding my registration hostage..."
                          -Christian
                          • Stanley Rockafella
                            • Aug 2011
                            • 4062
                            #73
                            I'm still on the orig one
                            have you been lubricating the latch? I use a few drops of engine oil
                            • 15Michaeljoseph
                              • Aug 2013
                              • 1693
                              #74
                              hey same here! I do it with my monthly lube of the throttle pieces
                              • bavarianbrawler
                                • Feb 2013
                                • 33
                                #75
                                Probably mentioned before but the OBC/radio no longer working after a battery disconnect. Joy.
