Semi Broken Down in Needles, California
  • s14pwd
    • Apr 2012
    • 116
    So I have another issue now, the car feels like its on 3 of 4 cylinders. Was on the highway and it started to vibrate all of a sudden, think it was the road I continued, but a few miles later it didn't stop and I pulled over. Checked the air filter for clogs, there was a tissue, removed no difference. Checked plugs, they don't look good, number 2 specifically (brownish/blackish crust), I brought spares so I changed them all, no difference. I pulled each plug wire one by one, and unplugging 2 makes no difference. This morning I checked the injectors. Screwdriver test and all are clicking, switched 1 and 2, but the problem remains on 2. I check distributor cap and rotary, looks good, no carbon and nothing broken. I am fairly certain there is spark as I got shocked from each wire when I touched the car(this was not my intentional test, I was tired and touched the body of the car). I'm out of simple things to check. Everything's closed and its Sunday.
    I am fearing a headgasket, but will find out tomorrow when I see a mechanic with a compression gauge. Ant assistance or help is really appreciated. I think I may have to send the m3 home on a truck...
    Is anyone in the area or can help in some way? Obviously I would compensate with monies.
    Shaun
  • archie
    • 5448
    Can we get some help for the member? Anyone close enough with a trailer?
    He is from Canada and FAR from home.
    Pm me please.
    Thank you
    A
    88 M3 Diamantschwarz
    89 M3 Zinnoberrot
    56 Isetta
    LIKE ARCHIE'S on Facebook!
    • reelizmpro
      • 9559
      Check the press fitted elbow on the front of the plenum. Then check the brake booster elbow on the throttle body near the firewall as well as the intake boot. Check the exhaust manifold studs/nuts too. If number #2 seems weak, then a compression/leak down test is in order.
      88 M3 - LACHSSILBER
      89 M3 - ALPINEWEISS II
      • Farbin Kaiber
        Lil' Puppet
        • 29502
        http://www.autozone.com/autozone/acc...er=391378_0_0_
        This is an easy test that could help you diag.
        AutoZone, 4762 Arizona 95, Fort Mohave, AZ 86426
        Looks to be 16 miles out from Needles.
        ( 928 ) 763-5220
        Rental of the tool is usually $25, then $8-10 for the fluid, but it's an easy way to check headgasket without compression tester.
        • s14pwd
          • Apr 2012
          • 116
          Thanks for the suggestions, gonna go check right now.
          Do you think it would be safe to drive the car 16 miles there and back to get the tool on 3 cylinders?
          • Farbin Kaiber
            Lil' Puppet
            • 29502
            No, I wouldn't chance it if it were me. I'd try to grab a compression tester at the same time then. Maybe a nice person seeing you walking will give you a ride?
            • 89AlpineM3
              • 548
              Wish I could help, hope it's not terminal
              • AndrewBird
                The Mad Scientist
                • 11898
                Might check and see if the injector is firing. Plug may have come loose or something?
                • s14pwd
                  • Apr 2012
                  • 116
                  Elbow on the front of the plenum is attached at both ends and the 3rd end near the valve cover, is soft and no tears. Brake booster elbow, same looks good. Intake boot was just replaced and is still attached and looks good. Manifold is on tight with all bolts in place. Compression test tomorrow.
                  • s14pwd
                    • Apr 2012
                    • 116
                    Did the screwdriver method and heard them all clicking, also swapped 1 and 2 and the problem remains on 2, so I can rule out injectors.
                    • e30rapidic
                      • 2167
                      sucked up a tissue? have you recently had work done on it as a tissue can't get past an air filter. Hopefully there wasn't something else in there that may have bent the intake valves. Hopefully the compression test will read ok.
                      '87 325ic, powered by S50.
                      • s14pwd
                        • Apr 2012
                        • 116
                        Should of clarified, the tissue was on the intake side of the filter. Didn't go past it.
                        • E30_Pare
                          • 7801
                          if your thinking head gasket have you checked the obvious? Coolant in oil, oil in coolant, cold heater, white smoke from exhaust etc? Does the motor turn over easily? Your on a road trip? When was the last time the fuel filter was replaced
                          DREWLIENTE
                          1$ PShops PM me
                          • E30_Pare
                            • 7801
                            Now that i think more about it. You should have some basic tools. I'd pull the valve cover and check for a broken rocker
                            DREWLIENTE
                            1$ PShops PM me
                            • s14pwd
                              • Apr 2012
                              • 116
                              I checked oil in coolant, looked clean, and I checked coolant in oil via the dipstick and nothing to indicate mixing. I remember reading that sometimes head gaskets can go at small amounts, resulting in no compression and no mixing, hence my guess. Motor turns over fine and no white smoke.
                              Yes I am on a road trip, the filter was just changed 8 months ago <1000 miles.
