I OFFICIALLY hate my engine
  • itskingsteelo
    • Jul 2013
    • 1340
    as the title states, I now officially hate my engine. I cant fucking wait to swap out my engine. for one this engine has NO power. (not saying this is true about all BMW engines, just mine in general) and two my idle keeps taking a shit on me, it use to rev high so I cleaned everything out and replaced some hoses and even got another ICV and it worked fine for a little while and now this piece of shit is jumping idle. as soon as I start my car it revs up to 3k rpm and comes back down to 1k, THEN it just jumps from 1k to 2k up & down up & down up & down. I had to drive to work like this on the fuckin freeway today. anyone got any suggestions? any help is appreciated.
    Originally posted by dvck
  • AndrewBird
    The Mad Scientist
    • 11898
    You likely have a vacuum leak or a bad/dirty ICV. Have a smoke test done and fix any leaks.
    Also, do a stomp test and see if there are any codes stored.
    http://www.pelicanparts.com/bmw/tech...de_Reading.htm
    • efficient
      • Feb 2012
      • 3312
      When the car is at operating temp and hot, spray some carb cleaner around the intake manifold area. Just hear if the motor changes sound and if it does you have a vacuum leak. If you dont want to pay for a smoke test.
      • flyboyx
        • 8371
        nitro's advice is good. i would follow it if i were you.
        if that doesn't work, sell the car and get a '73 pinto.
        Gigitty Gigitty!!!!
        • slammin.e28
          שמע ישראל
          • 12054
          Is your motor a M20??
          • itskingsteelo
            • Jul 2013
            • 1340
            thanks guys, if I wasn't at work right now I would get on it asap. unfortunately im here till 230 and im already dreading the drive back home. but I will follow your suggestions.
            yes it is, 87 325e
              • 34844
              time to swap in an S54
              • EyExR
                • Jan 2011
                • 959
                Yeah. Not a fan of the M20 any more. It's loud, it's bitchy, and it's low on power... Oh well.
                My 325iX DIY Threads:
                Front Wheel Bearing Replacement
                325iX Rear Subframe Bushings and MUCH more w/pics!
                325iX Steering Rack Replacement, Suspension, & Oil Pan job w/pics!
                • itskingsteelo
                  • Jul 2013
                  • 1340
                  thought of that, also thought of rebuilding the engine and boosting it but im afraid itll take a shit on me again so im gonna go with a different engine.
                  agreed, it sounds like its going 60 when its only going 15 I hate that shit. I gotta do my suspension before I can do a swap on it so im stuck with it
                  • MPLFoster
                    • May 2013
                    • 1490
                    i love my m20...
                    form.follows.function IG @mplfoster
                    • Roysneon
                      • 4505
                      How to tune up m20
                      Change vacuum lines and ICV
                      If that does not work, s54 swap.
                      Originally posted by mbonanni
                      I am a pursit now.
                      • slammin.e28
                        שמע ישראל
                        • 12054
                        Originally posted by Roysneon
                        How to tune up m20
                        I think that's a direct quote from the Bentley manual.
                        • jhaurimn
                          • Nov 2012
                          • 2224
                          Did you just have the battery disconnected? If so, engine has to relearn its idle, so rpms will go up and down occassionally for a few drives.
                          Current:
                          1989 325i
                          1988 M3
                          1987 325ic
                          Past:
                          2001 330ci
                          2001 M3
                          • Roysneon
                            • 4505
                            The Haynes manual lists the last step as S50US, it also states that the S50US is a real //M engine. Just another reason it's Bently manual ftw.
                            I am a pursit now.
                            • TurboJake
                              • 3780
                              I will be a sad panda when my M20 dies.
                              If I/the car ever see that day. The body will probably just rot around it and the m20 will still be ticking along at 750k miles.
                              Leave Me Transaction Feedback
