Pnp tranny...how to tell if it's good or not
  • Mr. Burns
    • Aug 2011
    • 3516
    I'm in the midst of pulling out a getrag 260/6 tranny from an e32 m30 with about 175kmiles.
    Now the cars been sitting forever.
    The shifts are nice and smooth/notchy however the "fluidness" of the shift is very slow and sluggish.
    Kinda like sticking a piece of rebar in wet cement. It's slow and not quick and crisp.
    Could this simply be due to low/no/old fluid? Or would there likely be something internal, mechanical that would cause it to act in such a fashion.
    I don't want to buy a tranny that needs a complete rebuild, nor do I want to waste my time and $ on something that'll end up being a paperweight.
    Thanks!
    Originally posted by flyboyx
    i have watched my dog lick himself off a few times
  • Danny
    • 14216
    Install in vehicle and test drive.
    • Farbin Kaiber
      Lil' Puppet
      • 29502
      The context of this title on Craigslist brings an entirely different mental image.
      • flyboyx
        • 8371
        let him stick his penis in you and see what you think?
        seriously, that trans is pretty tough to come by. who gives a shit? take a risk. i would.
        Gigitty Gigitty!!!!
        • AndrewBird
          The Mad Scientist
          • 11898
          Unless it is in the yard because the tranny blew, it's likely good. Stickiness could just be gummed up old fluid. Get it and maybe rinse the inside out with acetone, drain and refill with fluid.
          As far as the transmission goes, your guess is as good as mine. ;)
          • TurboJake
            • 3780
            Run it through the gears spinning the input shaft while feeling for gear chewing. All you can do really.
            Oh, and drain a little fluid to see if it has metallic dust in it.
            Leave Me Transaction Feedback
            • LJ851
              • 7919
              You can also wiggle the input shaft to determine how worn the input bearing is. This is a pretty good indicator of mileage but takes a little practice to make an educated estimation.
              Lorin
              The M30 is God's engine.
              • SmokeE30
                • 1730
                I like to get yard engines and transmissions from cars that were crashed, a nice looking car in the yard always makes me wonder what is wrong with it that it got there
                Shawn @ Bimmerbuddies
                Bimmerbuddies LLC
                717-388-1256
                2971a Roundtop Rd, Middletown PA 17057
                bimmerbuddiesllc@gmail.com
                • Mr. Burns
                  • Aug 2011
                  • 3516
                  That's the deal with this tranny.
                  I did find out that it was the yard/beater car for awhile, so the tranny must if worked.
                  The underside is mad rusted. Which is why I suspect it's there in the 1st place.
                  Either way. $49 for a 260/6 is good, even if it does need a little work.
                  • Sea Aych
                    • Apr 2013
                    • 767
                    Was that the one from Kenny-u-pull?
                    1988 Atlantisblau Euro/Japanese 325i Cabrio
                    1989 Schwartz 325i - now M50 powered! - now very dead
                    1998 Toyota 4Runner Limited - gone
                    My 17,000km Big NA National Parks trip!
                    • Mr. Burns
                      • Aug 2011
                      • 3516
                      Not that one. But there is a cleanish looking b35 in tHat e32 from Gatineau. Cars rockers are shot, so is floor.
                      I'd snap up the engine if I knew the mileage. No docs or paperwork whatsoever.
                      • TobyB
                        • 5293
                        Might have had GL5 in it and gummed up the synchros?
                        That ate 'em in one 2002 4- speed I tore apart.
                        Flush it with ATF for a couple of fills and see if it smooths out.
                        Around here, $50 is a very good deal, and worth the effort.
                        t
