someone almost stole my car
  • fight4life28
    • Apr 2014
    • 821
    Yes our cars have pretty worn locks, I can drive my 87 vert with my 89 ix keys, It goes right in and turns just like the original key. Be careful, They might be back again knowing how to drive stick...
    • jalopi
      • 2370
      Lol no. It's when you turn your key 90* instead of the usual 45* required for the central locking system to kick in. When you double lock nothing can unlock the door save for the key or tearing the door panels off from the inside. It's effectively bulletproof; noone will be able to (within reason) open your doors. It's also a double edged sword though... if your key breaks or if something happens to your locks, you're fucked.
      • Sea Aych
        • Apr 2013
        • 767
        Originally posted by kickinindian
        thank god for people not knowing how to drive stick?
        Sometimes even lowers insurance quotes for desirable cars vs. automatic!
        1988 Atlantisblau Euro/Japanese 325i Cabrio
        1989 Schwartz 325i - now M50 powered! - now very dead
        1998 Toyota 4Runner Limited - gone
        My 17,000km Big NA National Parks trip!
        • RUFFLZ
          • Apr 2011
          • 3122
          Originally posted by Poorboyz
          Car locked in a closed garage.
          Sent from my 831C using Tapatalk
          damn beat me to it!
          My double lock must not be working on my e30 because when I roll my window down and try it, I can pull on the knob and release the lock.
          Which theoretically shouldn't happen right?
            • 34844
            Originally posted by Liquidity
            Being unable to put a car into reverse without the ignition turned on isn't a function of a manual car. Neither is not being able to start the car when you have problems engaging the neutral-safety switch.
            no E30 has a neutral safety switch. but you wouldn't know that - just stick it in "D". ;)
            • rmdashrf
              • Feb 2014
              • 207
              Originally posted by RUFFLZ
              damn beat me to it!
              Nope. You shouldnt be able to pull it up. Thats why they say dont double lock people in the car.
              I used to double lock all the time. Until my drivers side lock got to worn out. Too lazy to fix, so i always lock and unlock via the trunk, which surprises so many people. . . lol.
              • abrokenframe
                • Dec 2013
                • 146
                watched some asshole kid look in the windows of my car last night for about 30 seconds at about 1am. He then ran across the street and jumped into a car idling with a bunch of dudes in it. Almost grabbed my bat.
                Luckily I don't keep anything in my car for this very reason. Don't keep belongings in clear view!
                • Benjamin_Button
                  • Mar 2014
                  • 384
                  30 secs and you couldn't grab a plate #?
                  ~Stay Thirsty~
                  • Mo Brighta
                    • 433
                    Double Lock?
                    Originally posted by fresh_TD
                    How do you double lock?
                    My E28 535i has the double lock feature with central locking built into the driver's door. It works as described above:
                    Key turns left 45 degrees to unlock all doors, trunk, gas filler.
                    Key turns right 45 degrees to lock all above.
                    Key turns right 90 degrees to lock and deadbolt all doors. This means even if they break a window and try to pull up on the lock button, they cannot open the doors. The door lock solenoids won't allow the doors to unlock. unless the mechanism fails ... like RUFFLZ described. If it fails you can pull the button up. I have one failed solenoid, so I know this from personal experience. That said, the above 'double lock' method is good too, locked garages are more difficult to slip into.
                    Good luck with getting the door locks back into operation. Hope the idiots move on to a more attractive car like a Range Rover or Accord. And get caught.
                    Andy says "Be Seen, and Not Hurt!"
                    Lighting Upgrades front and back for 2002, E3, E9, E10, E12, E21, E23, E24, E28, E30, E32, E36, E39, and more.
                    Tail Light Improvements keep them off your tail.
                    Headlight protection saves headlights from breakage.
                    • abrokenframe
                      • Dec 2013
                      • 146
                      The car was across the street and I couldn't see it through the trees until he jumped in it. As he was driving off I tried, but the car was too far being that I'm on a second floor of an apartment.
                      Ryan
                      • AndrewBird
                        The Mad Scientist
                        • 11898
                        Maybe that kid was just an enthusiast? I check out other people's cars all the time.
                        Also, a new lock set with keys is available from BMW for like $150. Includes door locks, trunk lock, ignition lock and I believe 2 keys.
                        • Bronzites
                          • Mar 2014
                          • 9
                          Maybe post a sign in your window at night? Something along the lines of:
                          Attention: Theives
                          I know about you and what you're attempting, so here's your fair warning that the police will be involved this time. How you do you know this notice is real and current? Because you're reading it, you stupid shits, and I'm watching you.
                          • Vincent Brick
                            • Feb 2013
                            • 879
                            Very interesting, I now want to get my drivers lock cylinder fixed, currently unlocks but not lock. I knew E36s had some similar feature, but not how it worked.
                            1991 325i Sport - Calypsorot Metallic - DAILY DRIVEN
                            WTB in SoCal: 8"/10" Lukebox, leather Sport steering wheel, 60L MotoMeter fuel gauge, Thule/Yakima roof rack
                            • brbahner
                              • Dec 2012
                              • 422
                              Attention: Thieves
                              Worst idea ever. what any thieve sees in a sign like that is. "im not actually watching you, thats why this sign is up to scare you." they obviously already know the risks of stealing a car, the sign comes off as a challenge or a "i dare you" type of deal.
                              • jake5
                                • Sep 2014
                                • 83
                                I am so glad this thread showed up,
                                I am going for a hidden power switch, I have a bunch of wiring to do anyways, Any one have any thoughts on the best way?BTW,
                                I had my house broken into and they hit me again three days later during a remodel, so take the warning "be careful they might be back" seriously
                                The cops said they usually come back if the first time they don't get in or don't get it all.
                                I F'n hate thieves. I Earn my shit,
