How do you guys drive so low?
  • Mr. Tasty
    • Jul 2011
    • 3421
    #31
    Originally posted by LJ851
    I see 4 possible scenarios.
    1) Car statically lower than the height of everyday bumps and smashes them.
    2) Spring rate too weak for ride height.
    3) Shock valving too weak for ride height.
    4) Girlfriend too fat.
    Solutions:
    1) Raise car.
    2) Stiffer springs or raise car.
    3) Stiffer shock valving or raise car.
    4) Acquire girlfriend with less displacement or see (2,3)
    quoted for truth.
    2014 Alpine White 335i MSport
    (Daily Driver)
    Full Mperformance Aero
    KW V2 Coilovers
    VRSF Catless Downpipes
    • Batz
      • Aug 2013
      • 303
      #32
      yeah i have 8K spring rates, guessing that what causes all the problems.
      and DrJosh , my 3 fingers are about an 1.5-2 inches.
      ill add some pics shortly to show you guys how my skidplate looks.
      • E30SPDFRK
        • 5709
        #33
        Originally posted by bataangpinoy
        you should all be ashamed
        bump steer is a hoe, and the camber curve of a slammed e30... well, its less than ideal lol
        Bump steer has nothing to do with lowering.
        Byron
        Leichtbau
        • Batz
          • Aug 2013
          • 303
          #34
          I had it on for about a month.
          • ELVA164
            • 4861
            #35
            Guess it doesn't really protect the drain plug, huh?
            • RedReplicant
              • Oct 2009
              • 270
              #36
              Well, decent springs with appropriate dampers, a skid plate, and recognizing what will hit hard before you get to it.
              91 318is - Gone
              16 VW GTI
              07 Aprilia Tuono
              • shameson
                • Jun 2012
                • 1507
                #37
                To reiterate what's been said, definitely change suspension. Especially stiffer shocks.
                My car probably sits as low as yours does, maybe a half inch higher now, and I've had my skid plate on for at least 4 months. It only has one small scuff and a scratch. And I have m42 with their no bueno low oil pan. I've only scraped the plate twice (construction zone pothole) and never do on any speed bumps. I have GC coils and talked with mark and jay to make sure I was getting the proper spring rate and shock valving when they put it together for me.
                I'm not saying everyone should spend a lot of money on suspension, but it's certainly worth every penny to make sure you have a good setup for what you use the car for and how low you like it. If you're scraping that much, you should raise it or upgrade to something better
                '84 Alpine 325e (Gone)
                '91 Alpine 318i (Gone) Click Here
                '92 Alpine 325i Cabrio (Gone) Click Here
                '91 Alpine 318is
                • Batz
                  • Aug 2013
                  • 303
                  #38
                  Well it does, at least used to, but I hit it very hard somewhere so now its bent quite a bit. The oil pan bolt used to sit about an inch/inch and a half higher. Don't get me wrong the skid plate is real nice quality and helped me a lot, it's my own fault that it's the way it is right now.
                  • Batz
                    • Aug 2013
                    • 303
                    #39
                    I raised my car up today, now its 3 inches from the lip to the ground. Didn't hit anything so far, and don't scrape where I used to. Will be driving like that for a while until I raise my engine up and get stiffer springs. Thanks
                    • E30Pacman
                      • Jan 2014
                      • 60
                      #40
                      That's the nice thing about being on 17's. Tuckin good amount of tire all the way round and still have great clearance, might have something with raised oil pan/tranny though. Just gotta be cautious that's the biggest thing.
                      "We at BMW do not build cars as consumer objects, just to drive from A to B. We build mobile works of art."
                      • bataangpinoy
                        • Jul 2008
                        • 1636
                        #41
                        ha. you're telling me an e30 lowered in excess won't have bad bumpsteer without caster/camber/roll center corrections?
                        check yourself before you wreck yourself.
                        My feedback:
                        http://www.r3vlimited.com/board/showthread.php?t=186328
                        http://e30tech.com/forum/showthread.php?t=74911
                        Instagram:
                        @gears_n_glory
                        @functionmotorsports
                        • MPLFoster
                          • May 2013
                          • 1490
                          #42
                          hmm...glad i didn't go with Megan Racing..................
                          I've had a slammed (1in clearance) Honda (CB7) since high-school and i rarely hit anything let alone something that would cause severe damage. Seems like you need to watch the road better.
                          I think better suspension and more awareness while driving would have solved your issues. Get that shit on lock and drop that bitch back down. yo..
                          form.follows.function IG @mplfoster
                          • SubDad
                            • Oct 2012
                            • 279
                            #43
                            I too am wearing my asbestos underpants.
                            I'm sorry*, but lowering your car to the extent that to drive it in a normal fashion on normal roads requires the spring rate of a chunk of damp oak, a kidney belt, the eyes of an eagle, the reflexes of a snake and the adrenal glands of a rodent is just, I'm sorry*, dumb.
                            I grant you that my E30 has fender gap that would make a dump truck blush, but it came that way and I don't have to come to grinding halt for every bump, and I don't get stuck on wet grass. (Dear God man...)
                            I'm pretty sure Jefferson didn't say "The price of oil pans is eternal vigilance." but hey, I'm Canadian and could be wrong.
                            *I'm not actually sorry. Using "I'm sorry" that way is a form of passive-aggressive politesse in a grand tradition.
                            • Batz
                              • Aug 2013
                              • 303
                              #44
                              lol
                              • SubDad
                                • Oct 2012
                                • 279
                                #45
                                What, no flames?
                                I am disappointed.
                                Bump for flames.
                                Not only are my underpants asbestos, I just found out all my attic insulation and the tiles in my basement and second floor are asbestos too. Great, great.
