What would you consider a major fault with the E30's
  • flyboyx
    • 8371
    #76
    i don't know what you get for fuel economy, but i get in the low 20's. that means by the time my trip meter hits 260 miles, my needle is on "e" and i am looking for a place to fill up.
    Gigitty Gigitty!!!!
    • rturbo 930
      • Dec 2005
      • 2627
      #77
      Originally posted by dnguyen1963
      Why? You can drive more than 400 miles per fill up.
      I've never gotten nearly that many miles to a tank. I usually fill up around the 300 mile mark.
        • 34844
        #78
        that's less than 20mpg. stock my ix got 21-22 and I consistently got 300 miles per tank. best ever was over 360.
        also, E30's don't have an "e". they have an "r" for reserve. ;)
        • DEV0 E30
          • Oct 2004
          • 8903
          #79
          What would you consider a major fault with the E30's?
          Many of their owners.
          • Reichart12
            • Aug 2012
            • 2165
            #80
            I guess I'm a wuss, after 200 miles Im looking to fillup lol. Generally get it done around 225. My gauge doesn't work.
            Instagram: Reichart12
              • 34844
              #81
              even if the gage doesn't work I'll bet your reserve light does.
              • 15Michaeljoseph
                • Aug 2013
                • 1693
                #82
                Originally posted by mucoyekul87ETA
                Dashboard cracks. I've been lucky to find my e30's clean from crack.
                Cracks are to be expected on a lot of older cars that aren't well taken care of.
                I f#*king love the m20.
                Agree... I think the only reason the dashes crack is because POs don't treat them, and dont use sunshades.
                --Mike
                (OO=[][]=OO) For Life
                • F34R
                  sLaughter
                  • 12376
                  #83
                  4x100
                  crappy rear suspension design(wished the front was like the e30 m3 or e10,e24 etc)
                  Instagram: @BWeissLeather
                  Current cars:
                  ~ '87 325 M30B35 swap
                  ~ '87 535
                  ~ 01 540 Msport 6spd
                  ~ '06 X5 4.8is
                  • DER E30
                    • Sep 2013
                    • 2349
                    #84
                    Originally posted by Red_liner740
                    I shake my head at my Jeep any time i work on it.
                    Right?!?!?!?
                    I have a 93 Grand Cherokee wheeling rig, the wiring is a total joke! All the insulation on the wiring is failing and making it short and BS. Should ask chrysler "why you no put real wire in it!?!?!?"
                    That and its alarm is CONTINUALLY going off! Like WTF jeep!?
                    BMW messed up on the subframe tabs that the engine mounts bolt to.
                    My E30's been good to me otherwise. wish it was 5x120 though...
                    -Christian
                    • marshallnoise
                      • Sep 2013
                      • 3148
                      #85
                      How so? Never heard this before.
                      Si vis pacem, para bellum.
                      New Hawtness: 1995 540i/6 Claptrap
                      Defunct too: Cirrusblau m30 Project
                      Defunct (sold): Alta Vista
                      79 Bronco SHTF Build
                      • DER E30
                        • Sep 2013
                        • 2349
                        #86
                        I don't think I drive that hard, I don't even drop the clutch or anything, but this happened with an M42!!!
                        What I did to fix it... That's .110 steel plate, as thick as I could use while still having full engagement on the engine mount stud.
                        -Christian
                        • marshallnoise
                          • Sep 2013
                          • 3148
                          #87
                          That is wild man. Makes me concerned about putting an m30 on a stock cross member.
                          • pandaboo911
                            • 2070
                            #88
                            Weird. I've had my s52 mounted on a non reinforced subframe for a couple years now. Maybe I should check for cracks
                            • rzerob
                              • Jun 2013
                              • 2315
                              #89
                              Ditto.
                              • Das Delfin
                                • Sep 2014
                                • 2293
                                #90
                                My '87 325i gets around 250/tank before the light comes on, with 100% city driving. The most I've gotten was around 340 on a trip with all highway miles. But something is wrong with my idle and there may be more economy to be had!
                                And my headlights shut off with the ignition, like the wiring diagram shows.
                                The steering rack is annoying but if I was allowed one mod only, it would be +2 cup holders.
