M20 swap into 318is power
  • cody_eppler
    • May 2013
    • 38
    Alright guys I decided to r3v it. As you can see from my title im putting a fresh m20 into my 91 318is. Everything has been going fine till now. I have the engine in on condor engine mounts and sits perfect. My issue is with getting power from the battery to the new engine harness. On the m42 engine harness the battery adapter came right off the harness. The m20 doesnt have this adapter. The adapter plugs into the male piece off of the fire wall right next to my ecu hole. So pretty much just trying to figure out how I will be getting power to my engine. Also on a side note im pretty sure that power plug came out of the 325is fuse box but my fuse box is more modern so it looks like it was changed. Any help would be gladly appreciated
    Cody-
  • varg
    Florida Turbo Man
    • May 2014
    • 3425
    Going by this: http://www.strictlyeta.net/technical/328i_6.html (I don't have an M20 car in front of me) and my car for reference.
    You would just put the above terminal on the power distribution block located on the firewall in your 318is.
    IG @turbovarg
    '91 318is, M20 turbo
    • cody_eppler
      • May 2013
      • 38
      bump
      • TobyB
        • 5287
        YOu need the M20 power distro block and long cable to the trunk...
        t
