Your most hated BMW engineering
  • Exodus_2pt0
    • 5943
    The e30 was one of the easiest cars I've worked on, in all manners.
    No wonder you kids are afraid of Audi's. ;-)
    No E30 Club
    • SoCal323i
      • 128
      Originally posted by E30_Narek
      I hate that my wheels are held on by lug bolts and not lug nuts.
      You're kidding, right?
      Mmmm
      Der Cherry Bomb
      • Julien
        • 7471
        -starter bolts
        -those two bolts on the bottom side of the hvac panel
        -having to separate the ball joints to replace shocks/springs
        -the adjusters for a/c, ps, alternator that are ALWAYS STRIPPED :-/
        Build Threads:
        • Vincent Brick
          • Feb 2013
          • 879
          The shifters. I have driven/sat in countless E28/E30/E36/E39 both street and track prepped, and only very few, which I am sure were aftermarket, didn't feel like absolute mush. My E30 has the worst shifter of any car I have owned even after full delrin bushing replacement.
          1991 325i Sport - Calypsorot Metallic - DAILY DRIVEN
          WTB in SoCal: 8"/10" Lukebox, leather Sport steering wheel, 60L MotoMeter fuel gauge, Thule/Yakima roof rack
          • Julien
            • 7471
            You probably didn't replace the little foam bushing behind the selector (that's held in with a pin) on the trans.
            Build Threads:
            • Dj Buttchug
              • Jun 2010
              • 7662
              Originally posted by rturbo 930
              Bitch clip.
              This x12938432
              Turbo M42 Build Thread :Here
              Ig:ryno_pzk
              I like the tuna here.
              Originally posted by lambo
              • Julien
                • 7471
                Originally posted by Dj Buttchug
                This x12938432
                my method isn't great but it works each time
                1. unscrew trans mounts
                2. take small flat head from behind clip (coming from the front of the car towards the back) and raise it up ever so slightly
                3. from the back of the clip slip a sturdy pick tool (i've used the same one for years) and slide it in the small void you just made... and pry.
                Build Threads:
                • b*saint
                  • 3794
                  That is the worst complaint on an e30. Damn. Maybe I should sell my e90.
                  Ma che cazzo state dicendo? :|
                  • Dj Buttchug
                    • Jun 2010
                    • 7662
                    I typically will bend my bitch clips so they are not so tight. The first time is always the worst but afterwards it makes it easy to R&R later.
                    Ig:ryno_pzk
                    • FredK
                      • 14760
                      I'd rather remove 50 bitch clips than to have to remove the transmission. Just buy a new one and smack the old one out.
                      The upper bolts aren't THAT bad but the last time I removed a transmission, the starter actually gave me the most trouble. The small dowel pin was very difficult to align upon reinstallation, and cinching up the starter bolts didn't get the dowel to pop in.
                      • Das Delfin
                        • Sep 2014
                        • 2293
                        oil filter is easy if you take out the coolant overflow (on an early model) and use a grabber-style oil filter wrench to remove. When the car is cold.
                        My main gripe is the metal they used for electrical connections is prone to developing a dark gray coating which reduces conductivity.
                        • Vincent Brick
                          • Feb 2013
                          • 879
                          No, I replaced that too along with the selector itself. Too bad I replaced it with another early one like what was on it, I'll have to change that if I ever get a DSSR. I've been told my shifter itself may be worn out, the bushing at the very bottom, or my issue may be in the trans itself.
                          But seriously, almost all BMW shifters feel like shit to me, and I've worked at two indie BMW repair/performance/race shops so I have driven A LOT of them if even just short distances.
                          • Sputnik
                            • Jan 2010
                            • 808
                            Removing the differential, especially the top mount bolts.
                            I hate those bolts with a f#cking passion
                            • Kershaw
                              • 11822
                              The UUC shifter kit in my friends s50 swap with ZF trans felt great. It's 12 years old and feels perfect. The IE kit (new) with my g260 feels waaay too tight, maybe in 12 years.... The ZF is also probably a nicer trans.
                              That said, to date I haven't driven a car that shifted nicer than my rx-8. It seriously felt like a bolt action rifle. Clean, precise, confident, clicks. Mmm. Boner poppin. ;D
                              AWD > RWD
                              • dnguyen1963
                                • Nov 2011
                                • 2648
                                Electrical gremlins are the worst.
