Your most hated BMW engineering
  • E30_Pare
    • 7801
    #61
    Originally posted by ELVA164
    This, very much. You guys have no idea what an actually tough job is until you've worked on British cars.
    holy crap this^
    Have any of you guys ever worked on a Interceptor? What a nightmare.
    Anyways worst part of a BMW? The one piece exhaust.
    DREWLIENTE
    1$ PShops PM me
    • Exodus_2pt0
      • 5943
      #62
      Originally posted by BillBrasky
      No, you do not have to remove any of that to replace the wiper linkage. Someone posted that misinformation on here when I did my first one in 2004 and I'm still pissed about it. I stopped halfway as I was pulling the dash and realized it could all be done from the outside. I wanted to reach through my 56k modem and strangle that SOB.
      This is pretty funny
      When I got my sedan with a snapped belt from my brother in 2011, I did a motor swap and replaced the linkage the same night..... I never even considered pulling the dash.
      I know this is a hard concept for some people, but sometimes, its better to go inspect things yourself before asking the internet. (Not a jab at anyone, just an honest opinion.)
      One thing I've learned, is that 90% of the people who give technical automotive information on the internet have no idea what they are talking about.
      When I went stage 3, EVERYONE said so much easier to pull the engine and transmission together. I went out and looked at it, and there is more clearance between the bellhousing bolts and the firewall than anything else I've worked on.
      So, I did it my way:
      3.5 hours later (while focusing on drinking beer as much as my tools. I don't get many days to myself, so I enjoyed myself and took my time.)
      People actually will tell you that removing the axles, driveshaft, clutch slave, then trans with the engine. Separate on the ground, reassemble, then install is easier than just the damn engine.
      Because they are inexperienced people giving advise.
      /rant.
      No E30 Club
        • 34844
        #63
        are you changing the timing belt or just the thermostat in that picture? :p
        • Exodus_2pt0
          • 5943
          #64
          That did make me laugh.
          Actually I cheated and didn't even touch the timing belt. Ended up doing it a couple weeks later when my starter took a shit. Only had to halfway pull the engine for the starter though lol. It's sad how quickly you can take the entire front end apart on these cars after a year of ownership.
          B5 life. The e30 was a cake walk!
          No E30 Club
            • 34844
            #65
            it's like those guys who say it's no big deal that a rotary needs rebuilding every 40,000 miles because they've had to take it apart so many times when it's broken that they can do it in their sleep.
            • Exodus_2pt0
              • 5943
              #66
              Because race car!
              No E30 Club
              • Jon325i
                • 6934
                #67
                It's been a while since I last wrenched on an E30, but past experience brings back these knuckle busting memories....
                The top two (forward end) bolts of the diff mount
                Rear wheels bearings
                Starter bolts
                M20B25 oil filter location (always had to wait for the car to cool)
                For the most part, I found the E30 to be a simple car to work on....just these few issues I pointed out were a pain for me.
                Jon
                Rides...
                1991 325i - sold :(
                2004 2WD Frontier King Cab
                RIP #17 Jules Bianchi
                • jhaurimn
                  • Nov 2012
                  • 2224
                  #68
                  Not really a pita, more of an inconvenience. It was always annoying replacing the oil filter on a hot m20.
                  Current:
                  1989 325i
                  1988 M3
                  1987 325ic
                  Past:
                  2001 330ci
                  2001 M3
                  • digger
                    • Nov 2005
                    • 6170
                    #69
                    oil filter is easy even with a set of headers, get a huge pair of pliers to get it started then get a rag or glove to stop yourself getting burnt and youre done. rear wheel bearing is not a job id ever do myself.
                    there are too many hated things with the engineering design to list.
                    • Northern
                      I like cupcakes & sh!tboxes
                      • 5262
                      #70
                      Originally posted by Sputnik
                      Removing the differential, especially the top mount bolts.
                      I hate those bolts with a f#cking passion
                      Studs. Seriously.
                      Originally posted by Julien
                      -having to separate the ball joints to replace shocks/springs
                      Only true on stock springs, and maybe like H&R OE sport.
                      Originally posted by E30_Narek
                      I hate that my wheels are held on by lug bolts and not lug nuts.
                      100% better to buy thread in studs than have OE studs that are splined and have to remove the hub to install longer studs or replace damaged ones.
                      Originally posted by varg
                      Oh, and they used 7mm exhaust studs. Why? There is no reason 8mm wouldn't have fit, and they're a lot easier to get.
                      The only thing that really bugs me about the E30 itself is why they didn't use anti-seize when installing the aluminum subframe bushing dowel in the steel mounting boss. Whoever was responsible for this design choice must have been sleeping in class when galvanic corrosion came up. Sure, the steel mounting boss is cathodic relative to the aluminum dowel, so the steel doesn't corrode, but the assembly corrodes itself together and when the soft, corroded aluminum breaks off in the chassis you're in for some real fun.
                      Both of these. I've never broken an M20 exhaust stud, but I've broken dozens and dozens of damn 7mm 24v studs. Plus a 7mm nut is like hen's teeth to find to weld onto a snapped stud.
                      The Al on Steel bushing sleeve has always bugged me as well.
                      Solution: don't wear gloves. Seems to work for the grease monkeys at the local hoist-em-up and rip-em-off.
                      I've been doing it wrong all along. If I take my clothes off, I should be able to fit through the skipass to open my trunk too?
                      I actually 100% agree with the M20 oil filter being a bitch. I've burned my arms so many times on the headers, plus the "screwdriver method" that a lot of people use is because of the location. Easy way out is flipping the filter housing, but I guess there are other issues with that.
                      Something else is the rear brake line tee being hidden above the subframe. It makes it a bitch to replace in the same spot, but most cars I see just leave the old one and throw a new one somewhere else.
                      Originally posted by priapism
                      Originally posted by shameson
                      • ThatOneEuroE30
                        • Dec 2013
                        • 8626
                        #71
                        E36 blower and wiper motors. Fuck those things. Also the exhaust manifold bolts. Them are no fun either.
                        1991 318i 4dr slick top
                        Mtech 2 turbo restoration
                        • Porthos
                          • Jun 2012
                          • 217
                          #72
                          My fucking exhaust broke and fell off on the freeway last night. How dare BMW not test exhaust pipe out till the end of time. I mean it was only 25 years old it should have lasted like 100 more years.
                          • Kershaw
                            • 11822
                            #73
                            Holy shit. Why didn't I think of that? A friend and I spent 14 hours dropping my subframe and replacing my rear brake lines because they cracked. I thought putting it behind the rear subframe was the most asinine design decision ever, but I didn't think to relocate it myself. :???:
                            Hopefully I don't have to do it again.
                            AWD > RWD
                            • Exodus_2pt0
                              • 5943
                              #74
                              Did you have proper hangers? You kids keep dropping exhausts on the road, you're lucky not to kill someone.
                              Someone with an ls swapped car posted about the same think on R3V FB the other day. Sad. V8 swap e30, can't even properly hang a fucking exhaust. Raises all sorts of questions about the rest of the vehicle.
                              No E30 Club
                              • nrubenstein
                                • 3148
                                #75
                                I hate that my wheels are held on by lug bolts and not lug nuts. It's so annoying trying to put a wheel back on because you have to line up the bolt perfectly with the hole rather than the wheel just sliding onto something threads and using a nut to hold it in.
                                Beats the hell out of pulling the hub because a pressed in stud is stripped/broken.
                                2002 BMW M3 Alpinweiß/Black
                                1999 323i GTS2 Alpinweiß
                                1995 M3 Dakargelb/Black
                                - S50B32/S6S420G/3.91
                                1990 325is Brilliantrot/Tan
                                1989 M3 Alpinweiß/Black
