E30 Key snapped -- no spare... What can I do?
  • jprastrullo
    • Jul 2012
    • 169
    Crap -- key snapped... No copy... have 2 blanks...
    What are my options?
    My '87 Alpinweiß 325is Build Thread | Parts FS | Parts Wanted | Feedback
  • 86gt635
    • Jun 2012
    • 99
    You got a dremel/file and a clamp? That original key is so worn you just need to get the blank close to the original shape and it should work fine. Otherwise, locksmith.
    • Kershaw
      • 11822
      As long as it's not broken off into anything important and you have all the pieces, you can go to a locksmith and have your blanks cut.
      Or diy it like 86gt said.
      AWD > RWD
      • ST1G
        • Oct 2012
        • 6689
        Partout.
        • FireFight
          • Mar 2012
          • 1367
          Originally posted by ST1G
          Partout.
          this
          i have brought snapped keys to my local hardware store and they have cut for me, they wont guarantee it but it has always worked
          WTB:m60b40 in PNW
          Zachary Ripley
          85 318i M50B25tu.
          92 525it 5 speed.
          80 244gl (m60 prepping).
          • McGyver
            • 4634
            Order a new key from BMW using your VIN and title. Then rebuild all your locks to work correctly with the new key. Finally, get a locksmith to cut your blanks to with with the fresh key. You'll go another 20+ years before needing to fix the locks.
            • jhaurimn
              • Nov 2012
              • 2224
              Have one blank cut with your broken key. If that newly cut blank works, have the other blank cut.
              Then, order a new key from bmw.
              Current:
              1989 325i
              1988 M3
              1987 325ic
              Past:
              2001 330ci
              2001 M3
              • bradnic
                • Jul 2012
                • 3554
                looks like a lame brass key - break/bend was inevitable.
                read the E30 OEM Key OCD Thread.
                HOWTOs:
                DB vert plastic bumpers
                OEM Keys
                MTech1 docs
                88 ix Lach/Card
                91 ic Calypso 3.1
                86 Cosmo 2.7
                OEM+ or bust!
                • jprastrullo
                  • Jul 2012
                  • 169
                  Called the locksmith -- he claims he might not be able to do it depending on where the key blade is broken -- because his vice won't be able to hold both... FML
                  • 86gt635
                    • Jun 2012
                    • 99
                    If you go to the dealer with your registration they can give you the key code. Locksmith will know what to do with that, surely.
                    • Stanley Rockafella
                      • Aug 2011
                      • 4062
                      Partout.
                      call a wrecker to tow it away
                      • Wh33lhop
                        • 11705
                        I ordered a VIN cut key from the dealer and it works fine with my existing locks--you don't need to change out any other locks. My hookup cost was ~$43, make sure they order the illuminated key and not the valet key or something stupid. You'll need to produce the title in your name and ID before they'll order it.
                        paint sucks
                        • BECKSTER
                          • Jun 2015
                          • 667
                          JB-weld
                          1990 Alpine 325is
                          1992 Schwarz 325ic (sold)
                          • Julien
                            • 7471
                            Get a replacement from the dealer like 3 other people have said. it will be a match for your car unless your locks have been changed previously. IIRC every bmw has 11? keys available when new
                            Build Threads:
