Is this an OK place to store my E30?
  • rex
    • Nov 2013
    • 150
    Common sense says if these buildings couldn't take the weight of snow, nobody in the northeast would build them. But on the other hand... People are dumb.
    What do you guys think? I put in the (now crooked) support beam as some insurance.
  • MR E30 325is
    • Dec 2008
    • 3300
    You're fine, assuming it was built correctly.
    Though if you really want to take full advantage of that self-added column, move it to the center (depth-wise) of the covering. The front edge only has half the tributary width as the center, and will never fail at that point if a homogeneous area load (i.e. snow) is applied to the structure.
    My previous build (currently E30-less)
    http://www.r3vlimited.com/board/showthread.php?t=170390
    A 2016 Toyota Tacoma TRD 4x4 Offroad in Inferno is my newest obsession
    • 2mAn
      SeƱior Mod
      • 20911
      Why not add a few more support columns?
      Simon
      Current Cars:
      -1966 Blue Boat
      -1969 Red VW
      -1986 White BMW
      -2006 Green Thing
      Make R3V Great Again -2020
      • CMBusch
        • Aug 2016
        • 181
        Woohoo! Someone local. I live outside of philly. That being said I can't imagine that we would ever get enough snow to make that cave in. I would however add another beam when possible just for the insurance. At least yours has a roof over it, mine just sits on the driveway under a covercraft cover.
        Originally posted by Melon
        Engine work takes patience and finesse.
        Suspension work takes anger, a big fucking hammer, and a torch.
        • wworm
          • Dec 2016
          • 1719
          someones an engineer!
          yeah I'd add one more in the middle if you're nervous about it
          1984 Delphin 318i 2 door
          • 2mAn
            SeƱior Mod
            • 20911
            whats that white stuff on the ground? - some Californian
            Simon
            Current Cars:
            -1966 Blue Boat
            -1969 Red VW
            -1986 White BMW
            -2006 Green Thing
            • amcp
              • 489
              Tons of cocaine. We have some in Missouri too.
                • 34844
                Add another post in the middle, I think it will be OK.
                but you're smart to think of that, a lot of people wouldn't..
                • Kershaw
                  • 11822
                  My SO's sister has a very similar looking car port, with no extra added center beam, and she lives in Littleton, NH. Crazy amounts of snow.
                  I think you're fine.
                  AWD > RWD
                  • rex
                    • Nov 2013
                    • 150
                    Engineering mindset. Thanks dude.
                    I actually had a center beam too, but after some really strong wind, the center post somehow worked its way out (I cut to rough length and just pressure fit them) and fell on my car !! luckily it didn't leave a mark. So I got to thinking about how to properly set the post in place, and then I thought, you know, do I even need these things anyway?
                    • rex
                      • Nov 2013
                      • 150
                      Good looking out, thanks yall
                      • Kershaw
                        • 11822
                        Lol, pressure fit them? The whole structure will flex in the wind making that pressure fit, as you found out, not a fit at all.
                        If you want the center beam to actually reinforce the structure, you need to dig down 2 feet, set the beam in, lag bolt it to a top cross member, and then fill the hole with concrete.
                        Or you know, just not worry about it, because the car port is probably pretty solid.
                        AWD > RWD
                        • AndrewBird
                          The Mad Scientist
                          • 11898
                          Why not just knock the snow off when it starts to accumulate?
                          • MR E30 325is
                            • Dec 2008
                            • 3300
                            I am literally a Structural Engineer.
                            Don't overthink this. Pull that front column and be done with it. Less another poorly implemented column falls on your car.
                            • kyleconstantine
                              • Apr 2014
                              • 1380
                              just put snow tires on it and beat it all winter.
