alen screw stripped !!!!!!!!!!
  • german g
    • Feb 2006
    • 1608
    my wwekend sucked, just normal maitenence turned into frustration..
    Here was my 1st problem
    Well, I was also replacing my dist. cap / rotor..I got 2 of the rotor screws off and BAM!!! the 3rd one is already stripped, WTF...Any ideas on getting a stripped alan screw out in such a tight spot?? Please help ..
    jimmy
    90is, longtube headers/straight pipe/mark d 18# 93 0ctane chip/18# injectors/vogtland springs/bilst. sports
    :firehop:
  • FL318is
    • Sep 2006
    • 1396
    Allen
    Can you drill into it?
    • Mike325
      • Mar 2006
      • 3685
      If you can't get a set of vice grips in there. you may have to remove the rad to get enough room. It sucks, but it might have to be done.
      Originally posted by Kershaw
      • german g
        • Feb 2006
        • 1608
        yea, I didn't want to have to remove the radiator, but it's looking bleak..There just isnt enoguh room to get a drill in there:(
        :firehop:
        • rede30
          • 4697
          a drill wont be needed, there is a big head on that sucker so some channel locks or vise grip will get it off. Radiator is so easy to take off its no big deal.
          • RobertK
            Kicked cancer's ASS.
            • Jun 2005
            • 5864
            Bolt out socket FTW!
            • AdironRider
              • Dec 2004
              • 3491
              I dont get it, removing the radiator takes like ten minutes?
              Back to my roots
              • mattdk318i
                • Jun 2006
                • 3953
                Vise grips FTW. Every M20 has done this to me. I think the PO's torque them down fearing they will come off
                • german g
                  • Feb 2006
                  • 1608
                  I never have removed it before, If I need to, then I'm glad it is that easy:D
                  :firehop:
                  • german g
                    • Feb 2006
                    • 1608
                    yea, i think thats what happened, the things were on super fucking tight.
                    someones got to know how to get this little plug out!!!!
                    :firehop:
                    • luvin my 325es
                      • Jul 2006
                      • 45
                      Same thing happened to me.
                      Used PB Blaster and small vise grips to remove.
                      I removed the philips head screws in the new rotor
                      and replaced with .5 8mm hex head, 16mm long bolts I found at
                      O'riellys. 8mm socket is soooo much easier.
                      • german g
                        • Feb 2006
                        • 1608
                        I tried that also..but the round head is hard to grip..I just picked up a small t-handle tap wrench and a small screw extractor...
                        :firehop:
                        • luvin my 325es
                          • Jul 2006
                          • 45
                          If you have a dremmel you could cut cut a slot in the screw head to fit flat screwdriver.
                          Easy out should work if you can get drill in there.
                          Good luck.
                          • moatilliatta
                            • 6158
                            pb blaster it then remove. :)
                            @Zakspeed_US
                            • german g
                              • Feb 2006
                              • 1608
                              tried pb, will not work...
                              I picked up a T handle taping wrench and a screw extractor, if that doesn't work, im gonna try the dremmel thing..
                              :firehop:
