Zf320 in a m20b25
  • savagesaint21
    • Jul 2018
    • 12
    Zf320 in a m20b25
    I have a zf320 laying around and an automatic 1989 e30. Would a zf320 fit my e30. I mean why not better gearbox overall.
  • e30austin
    • 15382
    it would. you will need a custom transmission mounting brace and selector rod to account for the 10% of tilt, since the bell housing pattern isn't 100% the same. e36m3 shifting assembly and driveshaft are required, and to make your life easy, i'd just run an e36m3 clutch kit and flywheel, so all the parts are from the same car.
    so short answer, yes, it will fit, you just need to get creative with a couple aspects.
    • 2mAn
      SeƱior Mod
      • 21062
      Basically the opposite of a G260 on a 24v motor right? Ha
      Simon
      Current Cars:
      -1966 Blue Boat
      -1969 Red VW
      -1986 White BMW
      -2006 Green Thing
      Make R3V Great Again -2020
      • e30austin
        • 15382
        precisely. a few PRO3 folks i know, started running ZF boxes, since Getrag 260 boxes have been getting more scarce. of course, neither are getting more common.
        • savagesaint21
          • Jul 2018
          • 12
          so to fix the tilt all i need is an e36 m3 shifting assembly? For the drive shaft would i need to shorten it? And do i need the full drive shaft or just half of it? Is there anything else im missing that i should know about? Thanks
          • Vincenze
            • Apr 2019
            • 1044
            For the M20, you have to cut and weld the shifter arm and carrier, turning them 10 degrees.
            The drive shaft is probably the correct length. The transmission output flange diameter is different, though. ZF transmissions have a bigger one.
            • TobyB
              • 5297
              CHEATERS !!!!
              no wonder I always lose...
              t
              is now fitting a Jerico sequential.
